Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Noisy Tappets/Lifters
Sports_GT
Galant VR-4 org Post #: 754223 posted 02/04/09 03:46 AM     Remind Me!  Send Private Message   Edit Post
Recently bought a Mitsi Galant SPorts GT Vr-4 and have noticed the tappets/lifters are a quiet noisy... Is this a big issue? What can i do to shut them up? I have try changing my oil, running 10W - 40 magnatech at the moment, car is at 150000kms. Cheers
| | | IP: (219.89.61.217) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 754225 posted 02/04/09 04:02 AM     Remind Me!  Send Private Message   Edit Post
If the car has a 4g63 or equivalent motor then yes the lifters are notorious for being noisy.
Buy some 3rd generation lifters ( much larger center oil passage ) and "hear the silence".
You can also check the cleaning thread on www.vfaq.com if you don't want to upgrade the stock lifters ( altho the amount of work is the same either way ).
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Edited by ktmrider (02/04/09 04:04 AM)
Posts: 3121 | From: Portland, OR | Member Since: 09/10/07 | IP: (220.216.108.115) | Report this post to a Moderator
GVR4_1057
Member ++
1057/2000
1604/2000
Galant VR-4 org Post #: 754239 posted 02/04/09 07:08 AM     Remind Me!  Send Private Message   Edit Post
^ Yeah the 3rd gen lifters fix it right away and you will soon forget what it even sounded like
Billy B,
1057 Back after 5 years JSB
1604 all fixed again.
1986 Audi 4KQ
1997 BMW E36 328I
Posts: 676 | From: Brucetown VA | Member Since: 09/03/08 | IP: (12.171.68.176) | Report this post to a Moderator
dmj
Rod Stewart
998/1000
Galant VR-4 org Post #: 754263 posted 02/04/09 08:31 AM     Remind Me!  Send Private Message   Edit Post
I did the third gen lifters on mine and it is still noisy, I have learned to live with it as the car runs fine.
Posts: 673 | From: orlando FL | Member Since: 02/02/08 | IP: (63.241.207.195) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 754271 posted 02/04/09 08:48 AM     Remind Me!  Send Private Message   Edit Post
Ya, I got 3rd gen and the tick came back. Not as bad as it used to be, but I give up.
1992 Nile black w/sunroof
Posts: 6007 | From: central Indiana | Member Since: 08/06/02 | IP: (69.243.156.102) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 754284 posted 02/04/09 09:19 AM     Remind Me!  Send Private Message   Edit Post
Quoting dmj:
While logging various cars, I've found that lifter noise will occaisionally be picked up by the knock sensor and reported to the ecu.
The ecu will then turn the timing down considerably.
Is your oil pan in good shape?
An oil pan that's been smacked can smash the pan up against the pickup, causing some variances in oil flow to the pump under different load/g forces.
This can cause one of the other causes of lifter noise, which is air getting entrained in the oil.
A bent pan bottom can also put the pan bottom at an angle to the pick-up. This can also cause cavitation, or a vortex to form under high g's/low oil levels that will let the pump swallow some air.
Since the air is compressible, it'll give you some intermittent tick when it gets up to the lifters.
If it's bent, straightening out the bottom of the pan so it has the correct clearance to the pickup should be added to the list of things to do the next time you have the car down for maintainance.
While you have it apart, inspect the gasket on the oil pump pick up tube to the front cover, as you might be drawing some air in there as well.
Posts: 3541 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.14.104) | Report this post to a Moderator
kryger
Galant VR-4 org Post #: 754490 posted 02/04/09 04:39 PM     Remind Me!  Send Private Message   Edit Post
^very good info to know, thanks
| | | IP: (71.224.139.152) | Report this post to a Moderator
eviLntt
eVIL_DNB
938/1000
Galant VR-4 org Post #: 758977 posted 02/14/09 07:03 PM     Remind Me!  Send Private Message   Edit Post
So apart from phantom knock, is there any other ill effects of lifter tick?
Posts: 1026 | From: Santa Rosa, CA | Member Since: 04/03/06 | IP: (75.55.196.62) | Report this post to a Moderator
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 759004 posted 02/14/09 08:56 PM     Remind Me!  Send Private Message   Edit Post
Long ago I noticed that some different brands of oil filters would cause the lifters to be noisy. I try to stick with a oem, Denso, Purolator pureone, Mobil or K&N filters. I also noticed that it would tick a lot using Mobil 1 oil. I used the Purolator oil filters and Schaeffer oil in my wife's talon and it only ticked when it got close to time for an oil change. I stole that motor and put it in my DD galant w/3G lifters and it hasn't made a noise since with 180k on the clock. A trick I used to use to help clean them out was to pour a quart of transmission oil in the engine and let it idle for about 10 mins and then change the oil. Used to help my tick before I upgraded the lifters.
816 of 1000
[email protected]
??? of 2000
[email protected] on 93oct
[email protected] on C16
[email protected] on E90
ASE Certified Master Technician
www.Performance-Alignment.com
Posts: 397 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (74.215.73.162) | Report this post to a Moderator
GIjoe
lol, Im an idiot
1562/2000
Galant VR-4 org Post #: 759080 posted 02/15/09 08:25 AM     Remind Me!  Send Private Message   Edit Post
I know this must be a noob question, but what exactly are 3g lifters? I know what lifters are, I want to change mine, since the tick is unbearable, thats why I want to know what the 3G denotation stands for. thanks
1991 Galant VR-4 1562/2000 SOLD as of 03/2016
1998 Subaru Forester
2011 BMW 1M
Posts: 1044 | From: Budapest | Member Since: 07/27/08 | IP: (84.2.72.19) | Report this post to a Moderator
dsm_drew
Galant VR-4 org Post #: 759085 posted 02/15/09 08:54 AM     Remind Me!  Send Private Message   Edit Post
The original lifters had a very small hole for the oil, 1mm IIRC. They have since been revised and new lifters have a larger oil hole. 3G lifters are the most recent revision, the third design.
| | | IP: (76.187.62.162) | Report this post to a Moderator
GIjoe
lol, Im an idiot
1562/2000
Galant VR-4 org Post #: 759176 posted 02/15/09 04:38 PM     Remind Me!  Send Private Message   Edit Post
ok thanks. but is there another name for them? how can I find and order a set? is "3g lifters" the oem name? or is there a company that makes these? did they come stock in some mitsus? (so I can find the original parts number)? thanks again
2011 BMW 1M
dsm_drew
Galant VR-4 org Post #: 759210 posted 02/15/09 06:29 PM     Remind Me!  Send Private Message   Edit Post
Most any place you buy them will call them "revised" lifters. OE part number is MD377054. I think Parts Dinosaur had them pretty cheap too.
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 759215 posted 02/15/09 06:57 PM     Remind Me!  Send Private Message   Edit Post
Quoting GIjoe:
3g = 3rd generation or the model year 2000 Eclipse.
Mike O.
#464/1000 - Sold
Posts: 3121 | From: Portland, OR | Member Since: 09/10/07 | IP: (202.232.182.70) | Report this post to a Moderator
dsm_drew
Galant VR-4 org Post #: 759314 posted 02/15/09 10:50 PM     Remind Me!  Send Private Message   Edit Post
The 3rd gen Eclipse uses shaft mounted rockers and a second spring on top of the valve spring to act as a lash adjuster. Doesn't have lifters.
Most people assume that "3rd gen" or "3G" refers to 3rd gen Eclipse, but its the "3rd revision" of the lifter design. These are the same lifters used in the EVO 8.
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 759360 posted 02/16/09 02:47 AM     Remind Me!  Send Private Message   Edit Post
Excellent, thanks for the correction drew!
Mike O.
#464/1000 - Sold
GIjoe
lol, Im an idiot
1562/2000
Galant VR-4 org Post #: 759367 posted 02/16/09 06:00 AM     Remind Me!  Send Private Message   Edit Post
Quoting dsm_drew:
Thanks. Thats what I was thinking...since the 3g eclipse doesnt even come with a 4G63 engine..I didnt know which other mitsu might have these revised lifters (was suspecting an evo but not sure which one) Thanks again for the parts number too!
2011 BMW 1M
Edited by GIjoe (02/16/09 06:02 AM)
Posts: 1044 | From: Budapest | Member Since: 07/27/08 | IP: (150.127.225.246) | Report this post to a Moderator
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 759474 posted 02/16/09 01:14 PM     Remind Me!  Send Private Message   Edit Post
where is the absolute cheapest place to get these? would used ones be a problem? I figured that you could get some from a wrecked evo for next to nothing
We didnt start the fire! Billy Joel:E39A expert
181/1000 half-a$$ rally-fart
1630/2000 Ballin!
1844/2000 unwillingly put in 'storage'
mirage turbo sold to a guy who will wreck it
2012 EVO, too bad its not a Mitsubishi
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (157.182.26.109) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 759489 posted 02/16/09 01:52 PM     Remind Me!  Send Private Message   Edit Post
They pop up on Ebay for about $7x for the set.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (63.253.227.122) | Report this post to a Moderator
dsm_drew
Galant VR-4 org Post #: 759594 posted 02/16/09 06:48 PM     Remind Me!  Send Private Message   Edit Post
Mike and GIJoe, you're welcome.
Many people install used lifters without problems. People sell them in the FS section of this board all the time. You can always give them a good cleaning before you install them, as shown here .
Parts Dinosaur has aftermarket replacements for cheap too, here. I know many people will say "stick with OEM only" but 1) somebody else makes them for Mitsubishi in the first place, and 2) they're lifters, not a critical part like an oil pump. Just another option.
GVR4_1057
Member ++
1057/2000
1604/2000
Galant VR-4 org Post #: 760127 posted 02/17/09 07:39 PM     Remind Me!  Send Private Message   Edit Post
I have had great luck with the partsdinosaur lash adjusters (lifters)in both cars.
Billy B,
1986 Audi 4KQ
1997 BMW E36 328I
Posts: 676 | From: Brucetown VA | Member Since: 09/03/08 | IP: (67.163.102.249) | Report this post to a Moderator
pachood_1953
Box Lover
1953/2000
Galant VR-4 org Post #: 760204 posted 02/17/09 10:10 PM     Remind Me!  Send Private Message   Edit Post
I have the topline(or Johnson Hy lift, I think) lifters in my car, and they are quiet as can be. After I built my motor that tick just drove me nuts.
Before you install them, make 100% certain you bleed them. Even new ones come loaded with oil
Nile Black 1953/2000 / Back to life
64 plymouth belvedere
99 Mazda Miata
86 Honda spree NQ50!
91 Mazda Miata
69 Caldwell Formula vee
XBOX live = pachood
Posts: 737 | From: eau claire, wi | Member Since: 09/20/06 | IP: (66.188.251.10) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.081 seconds in which 0.045 seconds were spent on a total of 14 queries. Turbo powered.
