Rear Subframe poly Bushings **comming to a end**
boostx
Orlando, FL
How may people would be interested in these bushing for the rear sub frame.
The will be made out of polyurethane. One soft for street and a harder one for the track.
I should be getting the Prototype in the next few weeks, (will post pics)
The price $140 for all four pieces depending on how people interested.(
It will not be necessary to remove the rear sub frame from the car for the installation of the new one.
He isn't offering sway bar-chassis busings.... He's making 'subframe' bushings, the pancake ones. I'd be interested but I just started the process of having them made for me as well so it's a week too late for me to jump on the bandwagon. Nice idea though, those are hard to come by. Did you buy a new OEM unit to get your specs from?
CP
West Simsbury, CT
I've got some spare new poly subframe bushings if anyone wants them. PM me and I'll take photos. I believe they're Energy Suspension.
jepherz
KC, Missouri
I did a fair amount of 'digging' and didn't find ANY subframe bushings for the rear besides Noltec, which I don't think are made any more. You sure you have REAR bushings there and not 4 for the FRONT?
I think he means that you can let it hang off the subframe bolt and slip these on and jack it back together.
KT
I hope not. They won't be in there tight enough if they aren't put in with a press.
Larry Parker
Metro detroit
I have solid delrin in my race car and they seem to be holding up just fine.... I would think that solid is the key for the racers... Also delrin is easy to machine...!
LP
These can also be made out of delrin without a problem but the cost is a little more and they are precision cnc lathed.
Nijasan
Gravette, AR
I want some of these ASAP. I have a 1G rear subframe sitting in my garage that I've been putting off installing along with a 4 bolt rear. I was just about to order these bushings in the OEM style.
Also, from what I understand, solid is what you always want when it comes to these. I was even considering a set of those aluminum ones that (I believe) Shearer sells.
boostx
Orlando, FL
The hardest one is going to be out of UHMW.
Which to me is very hard but this will be a little more $$
Rausch
Cleveland, OH
Which poly? The etheylenes, propylenes, and urethanes are all manufactured in the same way as the delrins, teflons and others in that they are mixed, but not at level commonly available to the end user. Those, among others, are almost exclusively cast (rough: rods, sheets), and machined down into useable parts.
You could however readily acquire straight urethane (IIRC) and pour it into a mold though.
So long as you had the right dimensions, anyone machine these with a lathe.
CP
West Simsbury, CT
Here's what I've got left:
Energy Suspension bushing numbers read (from top to bottom):
1008
1009
3174
Flat washer-like black pieces on right in second picture read:
1018
1020
Can anyone confirm where these go?
CY - Are there any other numbers on them or do you have the part number that is on that sheet they are laying on? Somethings not matching up.
Here is the chart for how to read the part numbers from ES.
Explanation of Set Numbers
Part / Set Number Example- 3.4101-R
Manufacturer-
Example "3"
1- Suzuki
2- Jeep
3- General Motors
4- Ford Co.
5- Chrysler Co. & Mitsubishi
6- Scout/International
7- Nissan/Datsun
8- Toyota
9- Universal Application
10- MG
11- Mazda
12- BMW
13- Ferrari
14- Isuzu
15- Volkswagen
16- Acura & Honda
17- Volvo
18- Saturn
19- Subaru
General Description-
Example "4"
1- Motor & Transmission Mounts
2- Spring Bushings
3- Control Arm Bushings
4- Body Mounts
5- Stabilizer Bar Bushings
6- Spring Isolators & Strut Stops
7- Strut & Tracking Arm Bushings
8- Shock Eyes & End Links
9- Universal Applications
10- Rack & Pinion Bushings
11- Lubricants
12- Apparel: Shirts, Caps
13- Tie Rod & Ball Joint Boots
16- Steering Couplers
18- THE HYPER-FLEX SYSTEMâ„¢ Master Bushing Sets
Set No.-
Example "101"
101
102
104,
etc.
Color-
Example "R"
G- Black
R- Red
