Sold: 520/2000, Great condition, Columbus GA, $5,500 obo!
RebuiltVR4
Ft Benning, GA
call or text 720-737-0918 with any questions
rebuilt title, due to cosmetic quarter damage that was repaired. The car went through a full inspection before being given the rebranded title.
I have 100+ photos of the Resto/Rebuild on this car for anyone who's interested.
body is a 8/10
interior is a 8/10
Tires are Kuhmos, great condition about 80% tread remaining. Brake pads are newer, clutch is new and flywheel was recently resurfaced. The interior has been fully stripped, cleaned and reassembled. the carpet has been dyed to black greatly reducing the appearance of stains and wear.
rust free, southern car its whole life!
****additional repairs/modifications include:****
- HKS 272 Cams
- Ebay MBC
- EVO 3 16G turbo w/ new OEM wastegate actuator
- Dump pipe
- 3" ca- less turbo back exhaust
- CUSCO front strut bar
- CUSCO rear strut bar
- (not installed) Rebuilt 20G turbo
- AEM Wbo2
- ECMlink v3
- New windshield
- Replaced passenger rear tail light
- New front struts
- New OEM plugs
- all new fluids, less than 100 miles ago
- New OEM airfilter
- New front inner tie rods
- New front outer tie rods.
- New front ball joints
- New driver side front lower control arm
- New front sway bar endlinks
- New front wheel bearings
- Front ABS rings deleted
- New front wheel studs
- Aftermarket steering wheel W/ removable/lockable hub adaptor
- Custom fabricated short shifter
- EVO 3 gauge pod with boost/volts/oil pressure
- Full engine wiring harness inspection/repair/replacement or old unusable connectors and pigtails (this took
- minimum 48 hours probably much closer to 72)
- rear seats replaced with no tears or rips in the donor seats
- The carpet has been cleaned and dyed black
- every interior plastic piece was removed and cleaned
- the vehicles floor pan was also cleaned. The area around the shifter has been steam cleaned.
- THE ONLY INTERIOR FLAW i have found IS a small *repaired* tear on the drivers seat bolstering ( I have photos of this as well)
-car will come with extra OEM pieces (door handle trim, misc other items)
I am selling because I have simply lost interest, I put a solid 6 hours a day for almost 2 months and im just burnt out.
I may be forgetting some info at the moment so I will add more to this later.
MORE PICS AVAILABLE ON REQUEST
Egalloway
Asheville nc
Cash plus a 900sp Polaris? Does say OBO so figured I would toss it out there. I can come to you with it cash and a car hauler.
RebuiltVR4
Ft Benning, GA
Quoting Egalloway:
No thanks man, only looking for cash sale.
