FS: '92 Kensington Grey GVR4 Partout
DSSA
PA
With the aspect of continuing to rebuild the new site for www.jnztuning.com I'm realizing that there's only so many projects I'm going to get on over the near future.
That said, I'm going to part out the roughest of my GVR4s (primered in some areas of the rear body which were not fixed to my liking).
The 4-bolt rear is currently sold, and the 5-lug hub conversion, front axles and prop shaft as well.
Other than that, the rest of the car is up for grabs.
Please email me at [email protected] with your needs.
Thanks!
DSSA
PA
Quoting MirageArt01:
Do you have the front 4 bolt knuckles?
Sorry, this car has a 5-bolt hub swap on it, which may already be spoken for.
I'll dig around the shop to see if there are any 4-lug setups up there.
DSSA
PA
Quoting Chaka_786:
do you have the vr4 front bumper support and triangluar fog light brackets?
I may have these on another GVR4 that I have in storage that I'm considering going FMIC on when/if I ever get time to get back on that car.
The bumper may be cost-prohibitive to ship through.
Josh
DSSA
PA
Quoting thomcasey:
How is the hood? My KG needs a good painted hood
The hood is white, and is beat. Sorry. That's most likely a trash item.
DSSA
PA
Quoting pot:
Josh, this is nonsense. You keep your car. /ubbthreads/images/graemlins/mad.gif
Pot,
No worries. I have more. ;-)
This one is just a little too much work to bring back.
Indianapolis, IN
Quoting DSSA:
Quoting thomcasey:
It was worth a shot. Thanks anyway and good luck with the PO.
GotInsulin
Philly burbs
Josh-
Any great-to-perfect front USDM bumpers in the stash? Beam is optional. I'm down in Willow Grove if so. Thx
DSSA
PA
Do you mean "perfect" as in "not cut/damaged", or as in "with perfect paint"?
I have this one up on the lift and will be checking things/starting to strip it today and tomorrow.
Josh
DSSA
PA
This car has cruise control and power steering still.
The dual piston front calipers are still available.
Josh
DSSA
PA
Quoting 91vr4:
Engine harness price?
I need to get the engine out before I can see what kind of condition it is in.
I just took a video of a cold-start of the engine, and have to do a compression test yet (my trusty, Snap-On compression tester seems to have taken a crap), then I'll yank it out and let you know.
GotInsulin
Philly burbs
Quoting DSSA:
Josh [/quote
Josh, more as in vein of not cut/damaged. Paint is less of a priority in my mind as my car is black. Thx.
91vr4
Memphis, TN
Quoting DSSA:
Quoting 91vr4:
Sounds good. Do you also have ebrake cables?
And also curious in the transmission.
DSSA
PA
Quoting GotInsulin:
Quoting DSSA:
Josh [/quote
I've got an uncut bumper cover here (support is cut, but not the bumper cover itself--foam backing is still there as well) in Nile Black.
I can get pictures in the light tomorrow if you're interested in it.
Josh
