Ryan Clark's 1991 Galant VR-4 1280/2000
strokin4dr
Savannah, GA
Board Name: strokin4dr
Badge number: 1280/2000
Build thread: CLICK
1991 Galant VR-4 #1280/2000
Summit White
Non-sunroof model
Dash plaque, numbered key fob and original keys present
Original window sticker
Owner’s manual, original bill of sale, and dealer sales info
Maintenance records since car was new
Body:
Rust free southern car originally purchased in Beaufort, SC
- Original exterior paint
- Fresh engine bay paint (2017)
- JDM front bumper
- JDM rear bumper
- JDM projector fog lights w/ Lamin-x clear protectors
- JDM power folding mirrors
- JDM keyless fuel door
- ’92 front grill w/ Fulltime 4WD badge
- ’93 Glass headlights
- Amber corner lights
- Hood shock kit
- 35% window tint
- GalantVR4.org rear quarter window stickers
Interior:
- ’89 manual seatbelt conversion
- ’89 underdash panel with pocket
- ’89 glovebox
- Starion leather headrests on stock seats
- Wideband gauge displayed in factory clock
- Momo steering wheel and hub adapter
- 4G Mirage rear view mirror
- Turboflanagan floormats
- Mofugas short shifter with custom bushings
- VR6eater shift boot
- Evo 8 leather shift knob
- Evo 8 radio
- Enviro-safe AC conversion
Engine (built 2017):
- 2.3 stroker engine
- 9:1 Wiseco pistons
- Eagle rods
- ACL bearings
- New factory 2.4L crankshaft
- Balance shaft elimination w/ OEM Mirage parts
- Rebuilt head with valve job
- L19 Head studs
- OEM composite head gasket
- OEM hydraulic tensioner
- ENGNBLDR SS valves and guides
- SuperTech dual valve springs & retainers
- SuperTech small OD valve stem seals
- Kelford 272 cams
- Fidanza adjustable cam gears
- 3G lifters
- OEM valve stem keepers
- OEM oil pump and front cover
- ’90 oil filter housing
- ’90 turbo waterpipe
- OEM water pump
- Stant SuperStat 180* thermostat
- OEM Evo 9 kevlar timing belt
- Custom painted zaklee upper timing cover
- New OEM lower timing cover
- Wrinkle black valve cover w/ 2x -10an fittings
- NGK BR7ES plugs gapped to 0.020
- Sparktech COP
- Black top CAS
- All new seals and gasket kit
- Fluidampr balancer
- ARP balancer bolts
- Shortened driver’s side mount
- Prothane mount inserts
Turbo / Intake / Exhaust
- GT35R in bolt-on FP housing
- FP 2.5" O2 housing
- FP oil feed line
- ExtremePSI oil return line
- SBR ported exhaust manifold
- New OEM upper turbo heat shield
- Custom turbo blanket
- Precision 46mm wastegate
- ETS FMIC kit
- Throttlebodys.com 63mm throttle body
- OEM EGR block-off plate
- custom machined FIAV delete
- FP intake with K&N filter
- stock bov with dodge garage mod
- 3” Apexi downpipe
- 3” custom exhaust with 18” Vibrant resonator and Vibrant 3” duel tip black muffler
Engine Management / Fuel / Electronics
- Socketed EPROM ECU
- ECMlink V3 w/ SD
- Omni power 4 bar MAP sensor
- GM IAT
- FIC 1120cc injectors
- Ingersoll Rand boost control solenoid
- Fuelab filter w/ -6an ss line & fittings
- FIC black black fuel rail (E85 safe!)
- Aeromotive FPR w/ gauge (custom mounted in stock brake fluid reservoir location)
- GM flexfuel sensor
- Innovate LC-1 wideband O2 sensor
- Walbro 450LPH in-tank fuel pump (E85 safe)
- Fuel pump rewire
- New OEM knock sensor
- Battery relocated to trunk (power distribution block in engine bay)
Transmission:
- Fidanza aluminum flywheel
- ACT 2600 Pressure plate w/ 6 puck disk
- Competition Clutch forged clutch fork & pivot ball
- OEM throwout bearing
- New clutch master and 3/4" bore slave cylinders
- SS braided clutch line
- JDM transmission 3.545
- 4 Bolt LSD rear diff
- Redline MT-90 fluid in trans
- Reline Heavy Shockproof fluid in transfer case & rear diff
- New OEM shifter cables
- Extreme PSI shifter base bushings
- Solid shifter cable bushings
- Rebuilt clutch pedal
Suspension / Steering:
- Feals Coilover setup w/ camber plates
- Whiteline Sway bars
- Afco custom rear camber kit
- Poly Bushing everywhere
- Delrin mustache brace bushings
- Delrin rear subframe bushings (not installed)
- 2G DSM power steering pump swap
Wheels / Brakes:
- 17x7.5 Bronze Rota Slipstreams
- 17/16 Brake master cylinder w/ correct fittings for conversion <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
- Goodridge stainless braided brake lines
Removed:
- ABS
- 4WS
- Cruise control
- EGR &amp; FIAV blockoff
- Charcoal canister
Previous Setups &amp; Parts:
- Built 9:1 2.0L
- Comp 101200 cams (272s)
- Evo 3 16g
- Bastard 20g
- FP HTA68 @ 34 psi
- Lower Shores MBC
- 3" turbo back exhaust from GVR4 that rolled on roof in HHI, SC <img src="/ubbthreads/images/graemlins/grin.gif" alt="" />
- Walbro 255lph HP fuel pump
- Evo 9 MAS
- Evo 9 560cc injectors
- FIC 850cc injectors
- FIC 950cc injectors
- KYB AGX struts w/ Whiteline springs
Parts waiting to be installed:
- Whiteline caster bushings
- JDM headlights
- 5 lug conversion
- ARP extended wheel studs
- 17" Work Equip 05 wheels
- New OEM hood insulation pad &amp; clips
