AKGVR4
I am trying to install my new LC-2 wideband. I have attempted to follow the installation manual but once all installed I am getting 2 red flash error codes
1992 Galant VR4 I have connected the wiring as follows: Red wire to pin 107, yellow wire to pin 4 black wire to pin 106
5 amp blade fuse on control box end of red wire.
Red wire from control box and DB gauge all connected together with red wire from ECU pin 107
Yellow wire from control box, yellow and white wire for DB gauge connected with yellow wire from ECU pin 4
black wire from control box and DB gauge connected with black wire from eco pin 106
I am have left the stock O2 sensor in the o2 exhaust housing connected
I have installed a bung in my down pipe 20" from the flange.
The error flashes are all before I have even connected the wideband sensor
Any help would be appreciated
