Old Vr-4
G
zompton
I never started a build thread for my other vr-4. So i'm starting a thread for it. No particular order just random things I make progress on as well as parts I day dream about /ubbthreads/images/graemlins/uhh.gif
New Nardi wheel installed with JDM hub & 15mm special order spacer. It moves the wheel the perfect distance from the stalks as they tend to get in the way during spirited driving.
Earls Solo bleeder installed on the new slave.
Mitsu longer slave rod. Not much longer than the bendix/ japan unit. I think the dsm rod is even shorter?
Found some sweet high temp silicone vacuum caps. Don't use the crappy rubber ones you find at auto parts stores. They don't last.
Fresh oil change.
JDM golden key. /ubbthreads/images/graemlins/confused.gif
89Mirageman
Stantonsburg, NC
Very nice so far. You're right about the rubber plugs. I bought a pack and one lasted a few months on my intake manifold before it cracked causing a vacuum leak.
I'm so not surprised by the pink HKS oil filter. /ubbthreads/images/graemlins/grin.gif
The gold key is interesting, I like the rounded off Mitsu diamonds.
G
zompton
Exactly, they look fine installed because you can't see the cracks until you squeeze them. This after only a few months. They basically dry rot in the hot engine bay. Chinese rubber. Well no one will see the filter installed unless you get under the car /ubbthreads/images/graemlins/blush.gif and I have not found a use for the pink vacuum caps yet. They don't seem to fit anything under the hood. Though the green, black & light blue ones fit a lot of things perfectly.
I've never had an issue with hitting the stalks while autocrossing my car with the standard steering wheel spacing. And that's pretty spirited. /ubbthreads/images/graemlins/dunno.gif
Wizardawd
Franklin, NC
My store sells the rubber caps as well as an assortment of the silicone caps.
Wiz
WTF, G? Ain't nobody care about your green vacuum caps and pink oil filter. We want to see the Hypertune intake manifold and OS Giken twin plate! /ubbthreads/images/graemlins/grin.gif
G
zompton
Wopper, you must have girly man hands /ubbthreads/images/graemlins/grin.gif were you wearing gloves? GST, I'm a baller on a budget just like everyone else /ubbthreads/images/graemlins/rofl.gif
I'd like to think I have pretty normal hands. /ubbthreads/images/graemlins/keke.gif Do you have sausage fingers? /ubbthreads/images/graemlins/hsugh.gif
Quoting G:
Sounds like DSM mentality to me...
JNR
ca
Damn, those must be some toxic caps! :lol:
G
zompton
No way man, I spend big $ on usdm hallman boost controllers. /ubbthreads/images/graemlins/grin.gif
turdb0
San Francisco, CA
I have a Momo hub, then I got a NRG quick release, and then I couldn't even reach the signal light stalk any more. ahha....
So I'm playing with the combination of parts I've got which is a Works Bell hub, with Works Bell hub adapter (30mm)... but I think I need to just order a NRG short hub and maybe a 1/2" hub adapter to get the perfect distance.
G
zompton
Bruh, you driving with your chin? I think 15mm is perfect and wouldn't go any more than that.
/ubbthreads/images/graemlins/rofl.gif @ all these dudes driving shitbox Galants looking like T-Rex
G
zompton
The spacer I added is this section here in red. Otherwise the distance without it is stock.
Turd, I have the e39a specific works bell hub fs nib if you need one.
G
zompton
New hood hinge installed. Got tired of the clackity clack clack clack.
