Rear hub bearing question
MellowVR4
Milwaukee, Wi
So, about a month ago I replaced my driver side rear wheel bearings ( they were growling pretty bad ). While I was in their I removed the abs ring on the one side since, now when I take off I have a slight vibration on that one side... Would removing the abs ring cause a balance issue to happen?
Any help would be great, thanks.
Did you reuse the correct shoulder bolts for the axle cups? Very important to use those in that type of load application.
Quoting MellowVR4:
I did not torque my wheel tho.
Really? Start there, I bet your wheel isn't fully seated.
