560 build thread
clevr4
Rhoadesville, virginia
Okay starting a new thread for all my little projects. 560 runs well, pulls hard, but has been brought to my attention that I have a couple issues that need addressing. I will start with the fuel rail issue. I have ordered a new rail and all the lines needed to mount my afpr on the firewall. The parts should be here by friday. I'll get to work either Sunday or Monday on the issue. I'll post pictures before and after. If i have any questions I'll be sure to post them here. Thanks guys
If you get some time, take a bunch of pics of your set-up. We can all take a peek and point out areas that need work.
As mentioned in the other thread we've noted:
Fuel rail set-up
Turbo oil feed line
WG upper nipple issue
Coolant vent line
We are here to help you out and with more pics we can help you get this car sorted out.
rgeier11
Chicago Suburbs, IL
Your manual boost controller. The other end of the boost controller should "T" into the BOV vacuum line.
Indianapolis, IN
I would avoid T-ing off the line to the BOV. There should be a nipple on your turbo J-pipe. Place the MBC (the new one you get) between the wastegate nipple and the J-pipe. Let the BOV have an un-tapped line to it from the Intake manifold.
Are you on a budget? If so, don't worry about the controller right now. The turbo feed line is far more crucial at this point. If your wallet is fat, then just a manual boost controller. It's far less complex to set-up and will do just fine as I don't think you need to play with boost ramp rates, lo boost, hi boost, etc.
Also I'd recommend buying up a copy of Corky Bell's "Maximum Boost" and a copy of Robert Garcia/Richard Bowen's "How to Build Max-Performance Mitsubishi 4g63t Engines"
Those two books are the bibles of what to do and why on your engine. Max boost will teach you loads about turbos and associated systems, the max performance book is a 4G63 centered book written with Robert Garcia of RRE fame. There is tons of info there.
Fiascoxl
Stuarts Draft, Va
Manual should be more than sufficient, but if you are running link a simple vacuum solenoid will open up a lot more options for you. Also the top port of the waste gate doesn't necessarily need to be used, it does help smooth the actuation out and lets the gate work faster. It will also allow you to get every little bit of boost out of the springs that are inside of it without the gate opening up prematurely. Put "waste gate vacuum diagram" in google images and it should bring up a ton of diagrams you can follow, adding the extra line to the top port on the gate is simple enough and should be done.
edit: ^ likewise, basic maintenance should be top priority with identifying and fixing leaks and such.
From your other thread:
Quoting clevr4:
Thanks man. I'll be able to ask more intelligent questions after I check those things in person. But what should my wastegate nipple connect to? And what would be a good fix for my turbo situation? Delete that boost controller and install a electronic one? I always that boost controller was kind of pointless, how would you know what you're setting the boost at? Guy said it was at 18lbs of boost but I've never seen it go over 15 on my gauge. What are the effects of over oiling your turbo? I can understand why under oiling is bad. Thanks for the input
Wastegate top port: It could be vented, or could be routed back to a boost controller. It was more of a question to you, rather than saying it was configured wrong or right.
Turbo situation: First, you need to identify what turbo you have. Take some pictures of the turbo; to include the compressor and turbine housings, as well as the compressor wheel. Post the pictures up so we can help you ID what you have. After we figure out what turbo you have, we can tell you what type of oil supply it needs.
Manual boost controller: Just pick up a Hallman Pro. The are cheap and work great. To set the MBC, you just guess and check. You turn it all the way down, and then crank it up slowly until you reach the desired boost level. You'll need an accurate boost gauge for this process.
Turbo oiling: Ryan (prove_it) pretty much summed it up in his post in your fuel rail thread. Bottom line, you need to ensure you're oiling system is properly supplying your turbo.
Don't be afraid to ask dumb questions. As long as you're humble to suggestions, and willing to learn, there are tons of people here willing to help. Also, as Ryan suggested, post up some more pictures of your setup. Pictures will tell us more than anything you can type here.
clevr4
Okay so I got fuel rail, started to repair the problem but run into another. It seems I don't need -6 AN fittings. Any idea what I have? And if so do they make adapters? Another this is. On the fpr side of rail the adapter you sugvested doesn't fit. Works fine on the first injector side. Kind of pissed I can't get this thing thrown together tonight. I guess you learn not to listen to everyone's advice and find out on your own.
[/url][/img]
clevr4
Do they make adapters for -6 to another soze? Or will I have to buy all new fittings or replace my whole lines with -6. This is highly frustrating. What to do about the long end of the rail? /ubbthreads/images/graemlins/banghead.gif
clevr4
I know, but what am I to do with this end? And my fpr has a fittING that's way larger than -6. So I will need some adaper to get back hooked up
The black fitting end looks like the end of the fitting that inserts into the hose. What's on the other end?
clevr4
The black fitting is a -6 45 degree. I held it next to it to get what size I actually need. What is the blue compared to the black? Blue is bigger and black is -6. Do they make adapters from let's say -6 to -8 or 10?
