drive line vibration 45mph and under
losermakesgood
Mishawaka, IN
The lobro joint is basically an enclosed u joint. Wouldn't it have the same characteristics as a u joint? Is the problem constant below 45? Or more in line with the rpms?
presterone
brunswick maine
Speed dependent I had it on the lift today the carrier bearing is really loose you can move the driveshaft up and down probably five inches.
