4 bolt rear/1G subframe/4 lug
luis84one
lynwood, ca
Is it possible to swap a 4 bolt lsd and 1g rear subframe and still keep my car 4 lug. What would i need to swap over to the 1g subframe offthe galant.. i know i could keep the galants rear but i would rather remove all traces of the 4ws /ubbthreads/images/graemlins/wink.gif
ktmrider
Tempe, AZ
Approach it from another angle.
If 5-lug TEL hubs fit on a GVR4 it's safe to aSSuMe the reverse works.
raptorWagon
Oak Harbor, WA
^Do this, just swap hubs from the trailing arms or swap the 3 bolt axle cups on the GVR4 trailing arms for the 4 bolt ones off the 1G. Either approach works. Don't need to swap anything over for the subframes, they are the same, the 1G just doesn't have the holes drilled for the rear rack. I replaced the rusty and cracked subframe with a DSM one in #1350.
