FS: All sold
89Mirageman
Stantonsburg, NC
Small 16g 4917805200- Got the turbo in on trade and it needs a rebuild for sure. 1/8" of shaft play and the compressor wheel is rubbing so it will need to be replaced IMO. Also the wastegate actuator is split so it will need to be replaced as well. Good for someone that may need it for parts or a DIY rebuild. Also has SS feed line and flange for the oil drain. SOLD
2g 609 maf with plug, honeycombs intact SOLD
