Vman911 Bezile Green VR4 #1667/2000
Vman911
Douglas county, Ga
Engine Mods:
6 Bolt block (bored .40)
Wiseco Pistons (9:1:0 comp)
Eagle rods
ARP Mains & Head Studs
272 Cams (Regrinds)
Evo8 springs & retainers
OBX Cam Gears
Aluminum Intake
Cometic Head Gasket
Aeromotive FPR w/ 6an lines from tank to rail
255 Walboro Fuel pump
Custom Coil-on-Plug setup
DNP S.S. Manifold w/O2 housing
FP Green Turbo (730CFM)
FIC 680 Injectors
Evo8 Maf
DSM link V3
Turbo XS Boost controller
Tial BOV
Tial 38mm Wastegate
Power Core FMIC w 2.5” pipes
Throttlebody Bored to 63.5mm (stock,58mm)
Drive Train mods:
Rebuilt Tranny w/ Evo3 HD input shaft, Evo3 First Gear
Dual 2nd gear syncro setup
Custom 6 puck sprung clutch, 2100 lb P-plate
Short Shifter w/ Bushings
Act lightened Flywheel, 11lbs
4 Bolt LSD Rear End
Interior mods:
Evo8 Steering Wheel
Evo8 seats F & R
HKS turbo timer
Autometer gauges (Oil, A/F, Boost, Temp)
White Face Guages
Exterior mods:
20% tint
Power folding mirrors (JDM)
17” Axis rims
KYB struts F & R
Sportline lowering springs w/ 1.5” Drop
3000 GT-VR4 Calipers (Front)
Cross Drilled / Slotted rotors 12.5” in front & 10” rears, HPS Pads
Polyurethane Subframe Bushings (rear)
8.5K HID's
