were can this be found
dsmless
tucson,az
really didnt know were to put this in but here it goes, Im looking at a old school colt like 70's and would like to build one with a 4g63 motor and while searching ran into this build thread about some aussie dudes car, he used a stock manifold with an adapter plate to make it a top mount turbo setup. Anyone know were this can be bought or made?
alansupra94
Wayne,NJ
Really doesn't look that complicated. Maybe a couple hours of measurements, CAD work (if you want to replicate it) and some help from a machine shop could easily get this done.
dsmless
tucson,az
yeah I thought so too, get a 1/2" of steel and mill or cnc it, then countersink one side to mount the manifold and the other to the head but wondering if anyone has done it or seen this before thats all
I wonder what was the idea behind moving the stock manifold slightly forward? Is 4g63 port/bolt spacing symmetrical? If shifting the manifold isn't necessary it seems like an easy enough job for a drill press and some rotary files.
JSchleim18
Long Island, NY
Ummm...just cut the flange off the stock exhaust manifold and flip it upside down, reweld, profit /ubbthreads/images/graemlins/dunno.gif
Quoting grocery_getter:
The bracket in the picture is for flipping the manifold upside down. Not for moving it forward.
The bolt holes *look* offset, maybe it's the angle the picture was taken at though.
rdomeck
Indianapolis, In.
Quoting JSchleim18:
Welding cast iron isn't as easy as you would think. It can be done but takes some care. Welding cast iron to mild steel a a little bit more difficult, but can still be done!
EgonOlsen
Denmark, Europe.
That particular guy made his own.
here they talk about how/what to make it of: click
looks like this:
raptorWagon
Oak Harbor, WA
Sigma-Galant has loads of tech and info along with ProjectzeroG if you are serious about the swap. What year Colt Galant/Lancer are you looking at? '71-73 you are going to have more clearance issues with the CAS than you will with a 74+, though 74+ will still require some massaging of the firewall regardless.
dsmless
tucson,az
good input I got the idea from project zero forums, just tossing the idea around of building a old school car and this type of turbo mounting caught my attencion
raptorWagon
Oak Harbor, WA
I was referring to using the 4-9 setup on a GA-GD Galant that were to have a 4g63t swap, not the on a VR4, instead of flipping a VR4 setup on the Early cars. I suppose something similar could be done like what the OP was seeking info on.
Toronto, ON, Canada
no but it would make the turbo point the right way in RWD applications with using the VR-4/Evo1-3 engine in RWD application, while still being low mounted. This wont work with RHD oldschool Mitsus though, because the steering box will be in the way.
raptorWagon
Oak Harbor, WA
Oh yeah, forgot your steering box is there too along with the brake master cylinder /ubbthreads/images/graemlins/frown.gif. For LHD that side is clear, where as I just have to worry about clearance with the intake manifold and my brake master cylinder on the opposite side.
RHD GC Galant with NA 4g63
