Galant VR-4 Forums » Galant VR-4 » Newbies » wheel offset???
wheel offset???
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 688308 posted 08/29/08 01:34 PM     Remind Me!  Send Private Message   Edit Post
I was searching and I still Don't know what it means, I just want to know what wheel offset is. Does suspension have anything to do with what we can run? If so, I have AGX with HnR lowering springs. I want new rims, But I don't know what offset is good. I want a set of 17X7 or 17x7.5 . So can anyone answer my question? Thanks
-Shane
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (24.143.227.174) | Report this post to a Moderator
Happy Birthday Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 688379 posted 08/29/08 04:11 PM     Remind Me!  Send Private Message   Edit Post
If you think of a wheel looking from the front/rear of the car, imagine the flat face where the center mounts to the hub and lugs. If that face is exactly centered between the bead on the rim (or think sidewalls if that's easier), that's zero offset.
Negative offset is the distance (in mm) that the mounting face is moved toward the inside of the wheel (wheelwell). this has the effect of making the rim and tire stick out farther from the car. Positive offset is where the mounting face is moved towards the outside edge of the rim. This has the effect of "tucking" the wheel in the wheelwell.
For the most part, the offset required has more to do with the width of tire you will be running than the rim width (except where you put a narrow tire on a wide rim, or start running into control arm clearance problems), but people typically pick offsets based on the rim width, which works fine most of the time, but the numbers people will quote are not always consistent, especially since not all tires of the same size have the same maximum section width. (usually it works out around widest tire you'd run on that rim).
Look here: How-to Section
For your size I'm guessing you probably want something around 38-40mm (positive) offset.
Edit: Whoops, flipped a sign by mistake.
Here's another picture.
Edited by Dialcaliper (08/29/08 08:13 PM)
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
justin22
Galant VR-4 org Post #: 688395 posted 08/29/08 04:30 PM     Remind Me!  Send Private Message   Edit Post
i have the same dilemma i have been looking for rims for mine.. there 17-7 currently but are curbed have been looking for rims for the last few weeks...looking for something lightweight but its been hard since nobody makes 4lug rims..
| | | IP: (71.231.110.248) | Report this post to a Moderator
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 688462 posted 08/29/08 06:54 PM     Remind Me!  Send Private Message   Edit Post
Quoting Dialcaliper:
Positive offset is the distance (in mm) that the mounting face is moved toward the inside of the wheel (wheelwell). this has the effect of making the rim and tire stick out farther from the car (you could say it "offsets it"). Negative offset is where the mounting face is moved towards the outside edge of the rim. This has the effect of "tucking" the wheel in the wheelwell.
For your size I'm guessing you probably want something around 38-40mm (negative) offset
Well said, except you've got your positive and negatives mixed up.
If you measure from the centre line of the wheel a negative number brings the mounting face inwards (towards the car, makes the wheels stick out) and a positive number moves the mounting face outwards (away from the car, makes the wheels sit in).
Most 17x7's and 17x7.5's you'll find on the market will have an offset around +38 to +45
I've got a set of 17x7" +32 Enkei's on my vr4 but I run much smaller tires than most of the us guys (215/40's)
There seems to be a big trend towards running big rubber on narrow rims over there which I must admit I don't understand.
My new rims are 18x9's with 235/40's
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (125.239.2.221) | Report this post to a Moderator
mj_rosenfeld
Galant VR-4 org Post #: 688463 posted 08/29/08 07:01 PM     Remind Me!  Send Private Message   Edit Post
You want around 5.5 inches of backspace, regardless of the wheel width. So to get the right offset, subtract half the width of the wheel from 5.5 inches. For a 7-inch rim that would be 5.5-3.5=2 inches or 50 mm. For an 8-inch rim that would be 5.5-4=1.5 inches or 38 mm. You can go a few mm either way.
Mike R.
| | | IP: (98.21.36.174) | Report this post to a Moderator
justin22
Galant VR-4 org Post #: 688491 posted 08/29/08 08:08 PM     Remind Me!  Send Private Message   Edit Post
hmm 18-9 sounds frinedly.. which rims? 4 lug still?
Quoting H05TYL:
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 688520 posted 08/29/08 09:13 PM     Remind Me!  Send Private Message   Edit Post
5stud not 4stud unfortunately.
work emotion xd9's
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (125.239.32.107) | Report this post to a Moderator
justin22
Galant VR-4 org Post #: 688525 posted 08/29/08 09:17 PM     Remind Me!  Send Private Message   Edit Post
yeah figures all the good rims i can find are for 5 lug... found some motegi tracklights the ones i use to have on my wrx and tirerack.com says they will fit but im skeptacle.
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 688526 posted 08/29/08 09:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting H05TYL:
You've got the trend backwards, the trend is to run 235's or skinny ass section widths on massively wide wheels like you are doing. Its quite the trend too, but thats it, a trend.
No one here runs big rubber on narrow rims. For the most part people run what you are suppose to run for a given rim width and tire. We run proper sized tires for the weight of our vehicle in order to be more competitive at local events. Running a 235 on a 9" wheel is retarded, if you think its cool, go buy a VW or an E30 bmw. All those fanboys will love your super stretched tires. There is no functional point to it.
If you can't tell yet, stretched tires are somewhat of a pet peeve for me.
Posts: 2962 | From: ellensburg,wa | Member Since: 01/14/02 | IP: (68.185.38.242) | Report this post to a Moderator
justin22
Galant VR-4 org Post #: 688528 posted 08/29/08 09:43 PM     Remind Me!  Send Private Message   Edit Post
i personally dont like them either...just not my thing...ellensburg u must go to college there? dident know there were too many other galant vr-4s in washington..
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 688530 posted 08/29/08 09:54 PM     Remind Me!  Send Private Message   Edit Post
I use to go to college here, but I grew up in kittitas county also.
Washington actually has a lot of GVR4's, they are just spread out and don't get driven very often. Probably over 10 of them in the yakima/ellensburg area alone.
justin22
Galant VR-4 org Post #: 688534 posted 08/29/08 10:13 PM     Remind Me!  Send Private Message   Edit Post
i just dont understand what you guys do there? i went to chelan last weekend at my timeshare i was bored out of my mind.. only ONE sbux and they dident even get my order right NO healthy places to eat...no gyms or anything id be poor there lol have to go pick fruit or something like everyone else does..
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 688545 posted 08/29/08 11:03 PM     Remind Me!  Send Private Message   Edit Post
you basically just came out and said "hey, I'm a city boy, look at me!!"
Jokes aside, there is lots to do here, just nothing indoors.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 688554 posted 08/30/08 12:07 AM     Remind Me!  Send Private Message   Edit Post
Yeah, there's nothing to do on this side of the mountains and picking fruit is the only career opportunity.
Please stay on the West side of the state.
-Mark
1051
Edited by turbowop (08/30/08 12:08 AM)
Posts: 11967 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 688570 posted 08/30/08 01:05 AM     Remind Me!  Send Private Message   Edit Post
Quoting kartorium:
Quoting H05TYL:
er... whoa.
Lets not get into 'trends' as a term of derision, I meant it merely as a description of an observation of a different way of doing things.
oh, and 9" is 228.6mm how wide is a 235 section tire?
you talk like i'm going to be running 205's
Hate takes alot of effort - some pet
Hard Snarker
1051/2000
Galant VR-4 org Post #: 688572 posted 08/30/08 01:26 AM     Remind Me!  Send Private Message   Edit Post
If you have a 9" wheel, why only run a 235 tire? The whole point of going with wider wheels is to fit wider rubber for better traction. 9" wheels deserve at least a 255 tire. May as well just go with an 8" wheel if you're going to run 235's or narrower.
-Mark
1051
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 688573 posted 08/30/08 01:28 AM     Remind Me!  Send Private Message   Edit Post
I'm drunk, Mark somehwat described my thoughts, but in a more coherent way.
Good luck with your thoughts on 9" wheel being 228mmm and running those 235's.
Edited by kartorium (08/30/08 01:30 AM)
Galant VR-4 org Post #: 688574 posted 08/30/08 01:32 AM     Remind Me!  Send Private Message   Edit Post
Not sure what tires you are running Hostyl, but does the manufacturer recommend 235s be used on a 9" wheel? If they do, I'm guessing it is at the bottom of the recommendation.
Stock evo stuff matches a 235 to an 8" wheel. I personally chose 225s for my 8" wheels, which was right in the recommendation for the tire I am using.
Too narrow a wheel and too wide a wheel both have their own negative effects. I personally wouldn't try to run a 255 on an 8", so I see what you are saying, but many have used 245s and been happy. That I felt was too wide also.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10862 | From: Michigan | Member Since: 03/05/01 | IP: (65.73.152.21) | Report this post to a Moderator
justin22
Galant VR-4 org Post #: 688582 posted 08/30/08 01:54 AM     Remind Me!  Send Private Message   Edit Post
sry dident mean to come off as a dick.. just saying for what "IM" into im more into INDOOR things because i work as a trainer and am always healthy as far as food/nutrition goes... all i seen for food was fast food and no gyms so nothing there appeals to me and I personally wouldent be able to make any $$... btw what rims were you running on ur vr-4 IF i remember right they were gold and 17s?
er... whoa.
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 688587 posted 08/30/08 02:06 AM     Remind Me!  Send Private Message   Edit Post
Here is a function of running stretched tires. So your wheels "tuck" & don't rub if you want to go low low low....
Try putting the correct size rubber on those wheels & you ain't lowering jack. Why not just buy narrower wheels? It's harder to get that fat lip look with narrow wheels, so it's more about looks than function to run that wheel & tire combo.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Edited by G (08/30/08 10:45 AM)
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (98.144.108.148) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 688595 posted 08/30/08 03:01 AM     Remind Me!  Send Private Message   Edit Post
Quoting G:
-Mark
1051
justin22
Galant VR-4 org Post #: 688596 posted 08/30/08 03:03 AM     Remind Me!  Send Private Message   Edit Post
hey wop what rims are you ur car? thx in advance.. i think andre is running 18-8.5s not sure what offset..
Hard Snarker
1051/2000
Galant VR-4 org Post #: 688597 posted 08/30/08 03:04 AM     Remind Me!  Send Private Message   Edit Post
I think it's listed in my member's rides page...but they're 17x8's with a +35mm offset. 5zigen FNO1R-C.
I'm not sure what wheels Andre is running now, but when he had the Enkei's they were the same size and offset as my wheels. I don't think he's ever run larger than a 17.
-Mark
1051
Edited by turbowop (08/30/08 03:06 AM)
justin22
Galant VR-4 org Post #: 688598 posted 08/30/08 03:15 AM     Remind Me!  Send Private Message   Edit Post
probably were 17s then i know there sticking out ALOT he was suppose to buy my 92gsx before it got towed and impounded he JUST rebuild the engine too damn it... anyways how much do they weight? been looking ALOT last few days to find rims for the vr-4 with NO luck.. if you ever have any free time and wanna help me take the car apart or put it back together and want extra $ lemme know dont feel like having it towed to andres shop anytime soon to have him build it sry for the thread jack..
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 688605 posted 08/30/08 03:49 AM     Remind Me!  Send Private Message   Edit Post
*sigh*
The wheels i'm buying already have very nearly brand new (60miles use) 235/40 tires on them - for street use it'll make no difference anyway.
For circuit use I'll be running 17" wheels with semi slicks.
So in no way am I harming the performance of the car (when it really matters).
Oh, and yes i'm doing it because I like the look - so what? so what if I wanted to run 10" rims with 215's - who cares?
If I wanted judging - I'd build a show car, get over it!
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (125.239.14.76) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 19 anonymous users are browsing this forum.
Generated in 0.115 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
