Galant VR-4 Forums » Galant VR-4 » Newbies » Can a TPS go bad?
Can a TPS go bad?
Chad989of2000
blows both ways and is skilled in magic with any mention of diarrhea
989/2000
141/1000
866/1000
1114/2000
Galant VR-4 org Post #: 356737 posted 07/06/06 07:20 PM     Remind Me!  Send Private Message   Edit Post
Never heard of it just wondering if that's what's causing my idle insanity. I can tighten and loosen it and it changes how the car idles (surging when all the way down), but if I somehow find a way to get it a good idle, the next time I start the car idle issues begin again. The BISS is almost all the way down. What happens as I currently have it set up is that the car almost stalls with a little throttle but eventually picks up. However, the car will stay at 2000+rpm even when I take my foot off, yet if I press the gas again it will dive down to almost stalling and mini-surging 600-800rpm...it does this when driving too. What is really going on?
Chadwick Atkinson (auto obsessive garage)
-'91 GVR-4 1114/2000
-'92 GVR-4 886/1000
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000 [Sold]
-'91 Stealth R/T TT [Sold]
-'93 NX2000
-'89 Taurus SHO [Sold]
-'99 Land Cruiser Overland Build
-'93 NSX [Sold]
Posts: 1790 | From: Livermore, CA | Member Since: 01/13/05 | IP: (71.254.102.38) | Report this post to a Moderator
324vr4
manly-loud yet refined
324/1000
Galant VR-4 org Post #: 356741 posted 07/06/06 07:38 PM     Remind Me!  Send Private Message   Edit Post
the only tps experience i have had is on my jeep. it wouldn't idle at the same rpm continuously and it was so sparadic at all other rpm's. i tried everything i could think of with no results so i took it to a mechanic and it was the tps. he said after about 80-100,000 miles they tend to crap out. i would try a new tps. good luck
Posts: 1240 | From: Bozeman, Montana | Member Since: 04/28/06 | IP: (168.103.6.142) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 356747 posted 07/06/06 07:52 PM     Remind Me!  Send Private Message   Edit Post
Yes, new TPS. Although you can test them to see if they are bad. Not a bad idea since they are kinda expensive.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.186.77.80) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 356759 posted 07/06/06 08:27 PM     Remind Me!  Send Private Message   Edit Post
Very expensive new, you can get a used one cheap and test it... its a personal choice I guess. It was very expensive for a new one though.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (24.149.159.155) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
866/1000
1114/2000
Galant VR-4 org Post #: 356855 posted 07/07/06 07:57 AM     Remind Me!  Send Private Message   Edit Post
How does one go ahead and test a TPS to see if it's functioning correctly? I'm all about the cheapest solution to any problem.
-'92 GVR-4 886/1000
-'91 GVR-4 989/2000
-'93 NX2000
-'93 NSX [Sold]
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 356874 posted 07/07/06 09:15 AM     Remind Me!  Send Private Message   Edit Post
RTFM!
The test isn't too confusing, but you need the procedure out of the manual. I'll try to get it to you this weekend if someone else doesn't come up with it sooner.
-Jon Barnes
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (12.150.68.71) | Report this post to a Moderator
Nijasan
polevault tard
1373/2000
Galant VR-4 org Post #: 356898 posted 07/07/06 10:38 AM     Remind Me!  Send Private Message   Edit Post
http://nija.dyndns.org/gvr4/Pages from 390 to 392.pdf
Right click, save as
Posts: 724 | From: Yuba City, CA | Member Since: 09/03/04 | IP: (206.14.213.30) | Report this post to a Moderator
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 356993 posted 07/07/06 04:31 PM     Remind Me!  Send Private Message   Edit Post
The TPS is a simple potentiometer AKA variable resistor. You find them commonly in old stereos, etc as volume controls. They can and do go bad. Most of the time the contact points on the wiper arm get dirty, stop smoothly transitioning from one resistance to another. In an old stereo you would hear it as static and popping when you turned the knob. Sometimes they can be cleaned (electrical contact cleaner), sometimes they can't. Sometimes they fail open, or at a particular resistance, appearing to be stuck even though they turn freely.
To troubleshoot one simply hook up a multimeter and measure the resistance while rotating the TB shaft. With the throttle plate closed it should measure around 1K ohms. When fully open it should be about 5K ohms. The transition should be smooth. They are easier to read with an analog meter because you can see the needle moving smoothly.
TPS adjustment and test
From the DSM VFAQ site:
DSM VFAQ
Stephen Firestone
1992 GVR4 #918 of 1K
Edited by s_firestone (07/07/06 04:39 PM)
Posts: 1610 | From: Park City, UT USA | Member Since: 06/27/02 | IP: (24.170.24.226) | Report this post to a Moderator
0 registered and 62 anonymous users are browsing this forum.
Generated in 0.149 seconds in which 0.112 seconds were spent on a total of 14 queries. Turbo powered.
