Galant VR-4 Forums » Galant VR-4 » Newbies » how to check timing belt
Ali
Galant VR-4 org Post #: 334232 posted 05/02/06 03:00 PM     Remind Me!  Send Private Message   Edit Post
I know my timing belt has been changed once already. I am currently at 155,000 miles. when is the next time i have to change it? And is there any method to check how good the current timing belt is? anything specific like marks on the timing belt or teeth. Sorry for the newb question.
| | | IP: (68.103.200.216) | Report this post to a Moderator
DSMonSUNsinONmon
Galant VR-4 org Post #: 334237 posted 05/02/06 03:26 PM     Remind Me!  Send Private Message   Edit Post
if i remember correctly you should change it around every 60,000 miles
| | | IP: (70.118.38.32) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 334243 posted 05/02/06 03:32 PM     Remind Me!  Send Private Message   Edit Post
There's not really anything to look for and if you see signs of fraying or cracking then it is about too break. The best thing to do is replace it so that you KNOW when it was done and go from there. Its too bad you're not out east, I do them for a few guys around here and I do it for pretty cheap.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.222.254) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 334304 posted 05/02/06 06:17 PM     Remind Me!  Send Private Message   Edit Post
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (24.145.203.12) | Report this post to a Moderator
Ali
Galant VR-4 org Post #: 334344 posted 05/02/06 07:52 PM     Remind Me!  Send Private Message   Edit Post
thanks for the helpful info! I guess this weekend i will check it out!
sjg
Galant VR-4 org Post #: 334735 posted 05/03/06 05:00 PM     Remind Me!  Send Private Message   Edit Post
My advice, if you don't have records of when it was last done, change it now. I've seen them go practically right at the 60k mile mark, with no real visible signs of wear. There are also some factors you can't just pull the upper timing cover and see that can easily contribute to t-belt failure (balance shaft belt). I have seen many mechanics that only replace the timing belt.
Do it now, if you can handle a wrench, do it yourself, its really not very hard.
| | | IP: (63.175.191.141) | Report this post to a Moderator
Ali
Galant VR-4 org Post #: 334753 posted 05/03/06 06:09 PM     Remind Me!  Send Private Message   Edit Post
thats true. I can do the work, its just i have to find the place to do it. living in apartments suck . Ive done a head gasket job on a 3.2 V6 Legend before and in case anyone has ever seen one of those its not easy. Im pretty sure the t belt is easier than that. Just got to find the place. Thanks!
| | | IP: (69.151.186.70) | Report this post to a Moderator
ohmegamike
75/2000
Galant VR-4 org Post #: 334924 posted 05/04/06 08:16 AM     Remind Me!  Send Private Message   Edit Post
If you really want some piece of mind, replace the water pump, hydraulic tensioner, and all tensioner pulleys for the timing belt and the balance shaft belt. It will cost a bit more to do, but then you KNOW when they were all replaced too. And they will last thru your next 60K mile belt replacement... Instructions are on vfaq.com btw-
91 Galant VR-4 #75
Posts: 95 | From: Solon, IA | Member Since: 05/23/05 | IP: (146.88.70.6) | Report this post to a Moderator
Polish
Dr. Pilosh Haagenscodyberger
Galant VR-4 org Post #: 334926 posted 05/04/06 08:26 AM     Remind Me!  Send Private Message   Edit Post
I used to have a Legend, those are some cramped engine bays. If you can work on one of those then the 4G63 should be no problem for you.
I agree with the above statement, replace it all. Tensioner, Pulleys, Belts, Water pump, and if you can do the BS elimination.
My car site
Old GVR4 #1186/2000
Posts: 8936 | From: NE, IN | Member Since: 01/10/05 | IP: (69.245.199.84) | Report this post to a Moderator
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.063 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
