Galant VR-4 Forums » Galant VR-4 » Newbies » What to look out for when buying vr4
Snaga
Newbie
Galant VR-4 org Post #: 1251283 posted 10/04/21 06:30 AM     Remind Me!  Send Private Message   Edit Post
Hi guys, im looking to buy my first galant vr4. Theres alot fo them in my country (indonesia) and if anyone can help what are things to look out for when buying? Any tips etc thank you
Posts: 1 | From: Tanggerang selatan | Member Since: 10/04/21 | IP: (180.252.165.222) | Report this post to a Moderator
lowcashleblanc
231/1000
Galant VR-4 org Post #: 1251284 posted 10/04/21 11:12 AM     Remind Me!  Send Private Message   Edit Post
Look at the boots on the rear steering rack, if they are swollen then the rear rack is leaking into the boots.
The hydraulic lines running to the back of the car are known to leak.
If rear steering has been deleted, check to see if the active toe has been locked out.
You can pop off the timing belt cover to see check the timing belt. It’s only two bolts to take the cover off.
Check for rust under battery tray.
Check for rust under brake booster.
If the shifter is sloppy, then the system most likely needed bushings. This can also cause grinds when shifting, but grinds can also indicate synchros are going out. (Dealing with this on my car currently)
If the seats are at all firm then they cannot be considered “Mint” the factory seat were supple and soft.
Check for factory glass, there should be Mitsu logos in the corners.
These are all bargaining points in my opinion. There is probably more others can add, this was just off the top of my head.
Edited by lowcashleblanc (10/04/21 11:13 AM)
Posts: 100 | From: Denver CO | Member Since: 03/19/13 | IP: (73.34.172.4) | Report this post to a Moderator
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.051 seconds in which 0.043 seconds were spent on a total of 14 queries. Turbo powered.
