Can I engine swap a 4G67 to 4G63?
AbR
New member
Queensland, AUS
Hi, I recently purchased a Galant Super Viento and was wondering if engine swapping the old 4G67 to a newer 4G63 is a viable choice? My end goal is to get more power out of the car and I am considering this as one of my options.
Sorry if this question has been asked before, I searched for a while and couldn't find anything.
Thanks /ubbthreads/images/graemlins/smile.gif
AllanL
NV
possible
ecu should be swapped as well.
depending on the 4g67 year, some parts of the engine control harness need to be modified.
AbR
New member
Queensland, AUS
Hi, i've found out much more about the car now.
It is a 1990 Viento, is there a way to check what year the engine is?
Also, are the engine mounts that fit to the E39A Galant the same as the ones on the E-E35A model? All four of mine are broken right now and I'm looking for replacements.
I suspect engine mounts will be different. The FWD and AWD Galants used different mounts and brackets due to crossmember design and engine positioning.
AllanL
NV
driver and passenger side supports may be the same.
but front and rear roll stoppers may be different between the FWD and 4WD as Iceman said...
AbR
New member
Queensland, AUS
I have recently received the car back from my mechanic, we replaced all four engine mounts with the ones from the AWD VR-4 and they all fit fine. I think I will come back to this thread later to post any updates on the engine swap, for science /ubbthreads/images/graemlins/smile.gif. Thanks everyone for the help!
