Galant VR-4 Forums » Galant VR-4 » Newbies » Wont start Send help!
JRuby
Newbie
525/2000
Galant VR-4 org Post #: 1250811 posted 05/23/21 02:09 PM     Remind Me!  Send Private Message   Edit Post
Good Afternoon all,
Last week I went to work on the vr4. I replaced the spark plug wires and put a new o2 sensor on. At this point the starter was on its last leg, it would not engage properly. So I ordered a new one ($66 on rock auto) and got around to it today. After replacing the starter the car will crank now, but will not start. I can see I am getting fuel pressure, not 100% sure on spark. I believe I have the firing order wrong on the wires. Can someone help me out with this. I will include photos of how the ignition coil is set. Sometimes when I crank the car it will read the RPM really high, other times normal ?
Posts: 7 | From: Stow, Ohio | Member Since: 08/22/20 | IP: (2603:6010:7004:c) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1250813 posted 05/23/21 05:01 PM     Remind Me!  Send Private Message   Edit Post
Do you have a factory service manual (FSM)?
Vol 1 - Chassis/Mechanical click
Vol 2 - Body/Electrical click
Start at page 734, Section 16-50 in Vol 2
or
Posts: 429 | From: Murray, KY | Member Since: 10/10/12 | IP: (24.179.241.196) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1250817 posted 05/24/21 10:28 AM     Remind Me!  Send Private Message   Edit Post
Both pictures show the plug wires not connected. Might want to start with that.
One coil does 1-4 the other coil does 2-3. In the OEM location the order is 4-1-2-3 left to right. Your coil looks flipped so try 3-2-1-4. If that doesn't work try the OEM order.
I love my crazy mother!!!
Posts: 1683 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
JRuby
Newbie
525/2000
Galant VR-4 org Post #: 1250818 posted 05/24/21 06:24 PM     Remind Me!  Send Private Message   Edit Post
Plugging them in would definitely be a start in the right direction! I tried the OEM orientation and that did not work. Will try that order and see if that nets me results. I ordered a spark checker just to be sure. I think this is a 2g ignition coil after reading some posts about the differences.
Thanks!
Imback
Newbie
Galant VR-4 org Post #: 1250819 posted 05/24/21 06:59 PM     Remind Me!  Send Private Message   Edit Post
You can just put a screwdriver into the spark plug boot and see if it sparks on the valve cover to check for spark. Even if it was in the wrong order it would backfire. I also once bought a non running 1g with similar issues and it ended up being a loose connection at the cas. Pull the plugs after attempting to start and check to see if there wet.
1316
Posts: 7 | From: Suffolk,NY | Member Since: 10/27/17 | IP: (72.69.11.247) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1250820 posted 05/25/21 06:34 AM     Remind Me!  Send Private Message   Edit Post
Quoting JRuby:
Thanks!
2G coil should be the exact same minus bracket? Since it's waste spark you could technically swap the paired wires and it wouldn't matter. 1-4, 2-3 or 4-1,3-2.
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.055 seconds in which 0.042 seconds were spent on a total of 14 queries. Turbo powered.
