Galant VR-4 Forums » Galant VR-4 » Newbies » Active Toe Eliminator Kit Extra Toe Out
HadesOmega
1373/2000
Galant VR-4 org Post #: 1250392 posted 02/03/21 11:47 PM     Remind Me!  Send Private Message   Edit Post
My GVR4 got hit in the driverside rear a couple months ago. The wheel got pushed into the body so I replaced the crossmember. I could tell I have too much toe in after I put everything back and got a wheel alignment done the other day confirms there is about 0.5" of excessive toe in. The alignment shop suggested I replace the trailing arm. When I put all the arms back in I didn't notice any damage to any of them that I could visibly see. I was wonder if the active toe eliminator kits like the one from Jays Racing would be able to fix this excessive toe in problem? Would it give me enough toe out get my car back into spec? I can see you can adjust the end in and out in addition to the eccentric bolt.
"Black Widow" 1991 Galant VR4 #1373/2000
1998 Mitsubishi Eclipse GST
1991 Toyota Previa 5-Speed
1989 Toyota MR2 Supercharged
1976 Datsun 280Z Turbo
Posts: 30 | From: San Jose, California | Member Since: 01/04/16 | IP: (2601:646:8800:f3) | Report this post to a Moderator
Galant VR-4 org Post #: 1250393 posted 02/04/21 10:40 AM     Remind Me!  Send Private Message   Edit Post
Are you still running the 4WS rack in the back?
Wondering how much toe adjustment you could get by adjusting the rear rack tie rod. Maybe not the best idea since the would be bushing compression likely.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10818 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
HadesOmega
1373/2000
Galant VR-4 org Post #: 1250399 posted 02/06/21 01:01 AM     Remind Me!  Send Private Message   Edit Post
I don't have the 4WS anymore, the previous owner took it out. This car is a franken DSM, I'm sure it has an eclipse crossmember because I just installed it and trailing arms from an Eclipse or 3000GT, A 4 Bolt LSD, and ingalls camber control arm.
Galant VR-4 org Post #: 1250405 posted 02/08/21 02:13 PM     Remind Me!  Send Private Message   Edit Post
So the new crossmember bolted up ok? fit over those large body studs with no issues?
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1250407 posted 02/08/21 02:54 PM     Remind Me!  Send Private Message   Edit Post
Which trailing arms? Dsm/gvr4 and 3000gt stuff are very different. The 3kgt arms will widen the rear tracking.
92 Galant VR-4 362/1000
76 Galant Hardtop
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2789 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (2601:601:4500:33) | Report this post to a Moderator
HadesOmega
1373/2000
Galant VR-4 org Post #: 1250432 posted 02/15/21 07:23 AM     Remind Me!  Send Private Message   Edit Post
Sorry I never replied. I wound up ordered the ATE kit from Volks Metalcraft and waiting for them to arrive. I inspected the trailing arm again and I can't see an obvious damage. Paul at VMC said I can get 3-4x more adjustment with the ATE kit so I'm hoping that will be enough.
Quoting iceman69510:
Yes the crossmember bolted up fine. It was pretty rusty and I cleaned it up a whole lot but I didn't have any problem lining it up and installing it.
HadesOmega
1373/2000
Galant VR-4 org Post #: 1250433 posted 02/15/21 07:29 AM     Remind Me!  Send Private Message   Edit Post
Quoting raptorWagon:
I think my car does indeed have 3000GT trailing arms because the previous owner mentioned that the rear track of the car is wider so he actually had the rear EVO8 wheels machined or shaved 5mm to give it more positive offset so it will line up with the front. I also notice the adjustments for the trailing arms are at the extreme outward adjustments on both sides. So I think this might have something to do with the 3000GT arms.
So what I think I will do is when I install the active toe eliminator kit I will adjust the heim joints as far out as I can for both. That way the eccentric adjuster bolt will be in the middle of where the adjustment range is. Right now it is all the way out and the adjustment marks on the bolts don't even line up with the mark on the crossmember. O_o'
Generated in 0.024 seconds in which 0.009 seconds were spent on a total of 13 queries. Turbo powered.
