Galant VR-4 Forums » Galant VR-4 » Newbies » Help Identifying Temp Sensor
ihugzombies
314/1000
Galant VR-4 org Post #: 1249997 posted 11/09/20 02:29 PM     Remind Me!  Send Private Message   Edit Post
This is the radiator fan sensor that sits at the bottom of the radiator. I can't seem to find which one this is exactly as the OEM ones seem to have the 2 paddles perpendicular to each other. The 2g sensor seems similar but the notch on the top of this one is different so I just want to be sure. This has the numbers 7L245M on the thread and a hallmark I can't make out.
The last thing I guess if no one knows, is there a sufficient replacement pigtail/sensor you can recommend that you use? I have this currently setup for a relay for the radiator fan.
Posts: 30 | From: Los Angeles, CA | Member Since: 08/29/19 | IP: (2600:1702:4660:1) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1250000 posted 11/09/20 08:04 PM     Remind Me!  Send Private Message   Edit Post
Good evening Jake. Iím no expert on this matter however the Thermo Sensor you have pictured seems to be OEM Mitsubishi for a USDM galant vr4.
For reference my sensor (from a Ď91 model) has the following etched into the sensor: 7K 21 85M ND (with a circle) on each face of the six faced sides. While not the same lettering/numbering as your sensor the font is the same.
I hope this information helps. More importantly what are you experiencing? Fan, Cooling, Heat, etc.?
182/1000
Edited by pot (11/10/20 06:05 AM)
Posts: 1542 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2600:387:2:809::) | Report this post to a Moderator
ihugzombies
314/1000
Galant VR-4 org Post #: 1250001 posted 11/10/20 12:33 AM     Remind Me!  Send Private Message   Edit Post
Thank you so much! This answered my question, I didn't know there was a difference with US & JDM spec
With that tidbit of info I was able to find the part correctly
For reference in the future its part #MB356704
Generated in 0.161 seconds in which 0.152 seconds were spent on a total of 14 queries. Turbo powered.
