Galant VR-4 Forums » Galant VR-4 » Newbies » Pics of custom 10an oil return line set up?
yeti
Nope still sticky fingers
Galant VR-4 org Post #: 1249861 posted 10/12/20 01:28 AM     Remind Me!  Send Private Message   Edit Post
Looking for pics of the extreme psi 10an oil return line kit installed.
I’m wondering if I should of left the steel braided hose long enough to loop around and hang under the car a hair or if it’s better to cut the SS line to 2-3” like I’ve done.
It came with enough length to bolt up but just looked funny doing a full circle before being bolted on
In hindsight I should of tried to bolt it on like that first and asked if it was cool.
~turbohair~
Posts: 785 | From: san diego california | Member Since: 10/13/10 | IP: (2600:1700:5020:1) | Report this post to a Moderator
Galant VR-4 org Post #: 1249864 posted 10/12/20 12:11 PM     Remind Me!  Send Private Message   Edit Post
I've never seen one looped, but at first glance that looks a bit short. Not sure that will cause you any issues as everything is attached to the engine block together.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10811 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1249869 posted 10/12/20 04:22 PM     Remind Me!  Send Private Message   Edit Post
Ya I’m going to pull it out because it’s leaking already and I haven’t even put oil back in the car yet.
If you can see the angle of the lower an fitting looks like it would fit a lot better if bent 5* more towards in the turbo drain.
Should I attempt to place it in a Vice and bend it a hair?
Before doing that I’ll be pulling it back out and replacing that SS line with one about 1/2” longer
But thanks good to know it’s not supposed to be looped
~turbohair~
yeti
Galant VR-4 org Post #: 1249870 posted 10/12/20 04:23 PM     Remind Me!  Send Private Message   Edit Post
~turbohair~
JNR
20/1000
Galant VR-4 org Post #: 1249871 posted 10/12/20 05:00 PM     Remind Me!  Send Private Message   Edit Post
The braided line hose looks 'tweaked' at the straight AN fitting side...It would appear rotating the 90° AN fitting about its axis, slightly clockwise may alleviate that. In addition, the hose looks like it may be a little short, in that it seems to 'pull' it at the straight side, further tweaking it. However, it's sort of hard to tell in the pic what's really causing that distortion. Regardless of reason, that's not a proper 'install' for these types of hose/fittings, as far as alignment, length, etc.
As for the other direction on the 90° fitting, be really careful bending the fitting since it's not only thin aluminum [crack easily] but the radius is short, so it would be real easy to kink the bend. Would that be detrimental to flow, etc. if that were to happen within reason, probably not...just have to use caution. Even so, it'd be a last resort IMO to modify the fitting.
Posts: 9778 | From: ca | Member Since: 04/23/04 | IP: (172.119.79.236) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1249875 posted 10/13/20 12:17 AM     Remind Me!  Send Private Message   Edit Post
mine's very short, but I ended up with some 45* fittings in there, and I have an HKS manifold so the placement is a bit different. On top of that, I have a -10 welded to the pan, which I like for eliminating at least one leak point.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3722 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (13.110.54.42) | Report this post to a Moderator
Generated in 0.034 seconds in which 0.021 seconds were spent on a total of 14 queries. Turbo powered.
