Galant VR-4 Forums » Galant VR-4 » Newbies » Wiring harness question
yeti
Nope still sticky fingers
Galant VR-4 org Post #: 1249686 posted 09/11/20 08:53 AM     Remind Me!  Send Private Message   Edit Post
So I looked up a 1g ecu pinout with colors ( attached ) and a good amount of my wires are different colors or lacking pins/stripes.
On another note thereís a - green wire/white pin stripe / red dash -
WIRE just hanging not connected to ecu at all, the pin out says this should be my idle switch or tps sensor, two things that would cause my idle to surge.
So I checked the pin location and there are wires there still plugged in, also a different color that indicates on the pin out.
But the idle switch and tps sensor wires have been molested, still seem to be connected and working ( visual )
Last but not least my knock sensor is consisting of 3 different wires being spliced into one ecu pin. TWO large brown With white pin stripe , and one small black with red dashs wire. ALL going into the original stock white knock sensor wire.
What to do? Where to start?
How can I check if my knock sensor is working properly? ( I have it set to boost gauge on Link and it flashed every now and then on my shitty tune )
How can I check if my tps or idle switch are working properly? The guy who tuned my car was mentioning the isc or tps something was not responding to adjustments on Dsm link.
My bad for all the questions is such a short amount of time, any help is greatly appreciated , also attached is the ecu pin out I followed
~turbohair~
Edited by yeti (09/11/20 08:58 AM)
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (2600:1700:5020:1) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1249699 posted 09/12/20 06:07 PM     Remind Me!  Send Private Message   Edit Post
Where do you start? Go here and download the service manual with the wiring portion in it.
Posts: 427 | From: Murray, KY | Member Since: 10/10/12 | IP: (63.150.211.69) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1249737 posted 09/18/20 02:42 AM     Remind Me!  Send Private Message   Edit Post
From what I can see half of that manual is missing, is the way to fix this issue to physically trace where each wire is going? And or run new wire from the sensor on the harness or where itís broken to the ecu.
The fact the colors are different is that just a thing from car to car? What 3 wires combined could be give me my knock sensor reading? As thatís working, I think, itís been tuned on this knock sensor system multiple times.
Just a bit overwhelmed. Gonna try to fiav and isc delete and hopefully the idle surge goes away but at this point I doubt it.
~turbohair~
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (67.36.2.68) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1249738 posted 09/18/20 06:49 AM     Remind Me!  Send Private Message   Edit Post
A lot to unpack here.
I prefer to use the diagram from ECMlink
PAH!
The wire hanging out in no man's land seems to be coming from the engine side of the harness and you say the TPS and idle switch seem to be intact at the ECU and judging by your photo's I agree. The green/white as the idle switch was only for the 90 model year. Should be straight green for 91+ and it appears to be hooked up via the ECMLink diagram and your photos. Looks like it may be the MAF reset. No idea why that would be cut but grab a meter and check if that's it. Are you running a MAF?
The large brown/white isn't a "wire" by itself. It's a shielded wire or twisted pair. The outer braids are tied together and grounded via the black wire to shield the internal signal wire from noise. These will be your knock and O2 signals as they are very important and susceptible to EMI.
Looks like your knock sensor wire has the tap on it and the O2 wire is cut completely. No bueno. You probably get CRAP gas mileage. Hook that back up ASAP.
You mention ECMLink. If you have it get a laptop and log IMMEDIATELY. Unclick everything so it's not so cluttered and just look at "Idle Sw", "ClosedLoop", "FrontO2", "ISCPosition", "ThrotPos"
At idle you want the idle switch and closed loop to be 1 with your front Os (Usually blue) cycling up and down with your ISC position cycling around 30 and throttle position at %0
Any of the above being off will cause the car to not idle correctly.
I would do all this before the block off.
I love my crazy mother!!!
Edited by CutlassJim (09/18/20 06:54 AM)
Posts: 1678 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1249739 posted 09/18/20 06:59 AM     Remind Me!  Send Private Message   Edit Post
Here is a log of a man with a dead front O2 (the blue line) and his ISC position is too high.
But he is still in closed loop and his TPS and idle swtich are working correctly
yeti
Galant VR-4 org Post #: 1250110 posted 11/30/20 12:34 AM     Remind Me!  Send Private Message   Edit Post
Ok so I did my best of rebuilding the o2 sensor plug (harness side ) and attached it to the universal Bosch o2 sensor.
I think I wired that correctly. ( heater wires are power and ground correct?)
And then disconnected my WB input to o2 on ecu and replaced it with the stock white wire to ecu.
While testing the o2 sensor on ACC I got no response from holding a lighter in front of the sensor for about 20seconds.
Iím gonna try to swap the two white wires as I believe they are power and ground with my red and black wires from harness, if I get no response from o2 after test drive tomorrow. I also have a Bosch direct fit coming in by tomorrow.
If any of that makes sense to anyone.
Also My WB sensor is broken flashing 7.4 so I have a new one otw to replace o2 sensor all together if I canít get this stock o2 figured out.
Just figured it was good to try and fix that anyways.
Also hereís some logs I posted up on ecmlink
~turbohair~
yeti
Galant VR-4 org Post #: 1250111 posted 11/30/20 12:38 AM     Remind Me!  Send Private Message   Edit Post
Pics of destroyed o2 sensor harness plug wires
~turbohair~
Edited by yeti (11/30/20 12:39 AM)
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1250113 posted 11/30/20 01:47 PM     Remind Me!  Send Private Message   Edit Post
About 5 years ago on my current car when I was fixing up the harness I was able to source a perfect condition 8G Galant plug and I run a 2G DSM front O2 sensor. Makes it nice to buy a nice cheap off the shelf O2.
yeti
Galant VR-4 org Post #: 1250114 posted 11/30/20 04:44 PM     Remind Me!  Send Private Message   Edit Post
Got the o2 working now,
I didnít save the settings to ecu on link so it was still trying to simulate NB with no signal.
I need to adjust tps still but hereís a pic of a idle log
~turbohair~
Edited by yeti (11/30/20 08:01 PM)
yeti
Galant VR-4 org Post #: 1250117 posted 11/30/20 08:02 PM     Remind Me!  Send Private Message   Edit Post
~turbohair~
yeti
Galant VR-4 org Post #: 1250118 posted 11/30/20 10:55 PM     Remind Me!  Send Private Message   Edit Post
got the o2 working at tps adjusted down to .55 at 0%
some logs in the ecmlink forums
~turbohair~
Galant VR-4 org Post #: 1250121 posted 12/01/20 08:36 AM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
I wired mine up the same way, and it worked great especially since I have a 2g O2 housing (2g O2 sensor is a bit longer harness length). The square style 4 pin connector on the 2g is pretty standard going forward on most Mitsubishis. Used in many other engine room locations too.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10842 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1250124 posted 12/01/20 05:02 PM     Remind Me!  Send Private Message   Edit Post
OK
So Iím running SD do I need to reconnect the maf reset? I donít see any open ports in my ecu that it could go to.
Also Iíve got the tps set at .55volts at 0% is that good enough or should I pop TB OFF and adjust tps physically?
O2 is all wired up/working and electrical taped so Iíll leave it until I can find a pigtail with sensor.
~turbohair~
yeti
Galant VR-4 org Post #: 1250129 posted 12/01/20 06:27 PM     Remind Me!  Send Private Message   Edit Post
Oh also a new fun fact I realized. I only have headlights when engine is running. And the brake lights & side markers get lit up when hitting the clutch
This is not a new problem just one Iíve failed to mention, itís been like this since I bought the car
~turbohair~
Edited by yeti (12/01/20 07:10 PM)
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.087 seconds in which 0.05 seconds were spent on a total of 14 queries. Turbo powered.
