Galant VR-4 Forums » Galant VR-4 » Newbies » Re: Source for knock sensor
mk2davis
398/2000
Galant VR-4 org Post #: 1249252 posted 06/30/20 01:01 PM     Remind Me!  Send Private Message   Edit Post
2 things. I don't know about 2g sensors, but supposedly the Evo sensor range is vastly different in range compared to the 1g unit. The Evo ECU and 1g ECU is supposed to have different filtering ability in the board. Or so I've read.
Received an email regarding the mirage knock sensor availability. National backorder, eta 30-90 days. This was from clubplug.net.
Posts: 157 | From: Ventura, CA | Member Since: 03/01/15 | IP: (47.148.36.40) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1249254 posted 06/30/20 02:10 PM     Remind Me!  Send Private Message   Edit Post
I changed mine about 10 years ago with a factory knock sensor, still okay....
The only thing I recall breaking down was the packing material/goo. This break down causes it to be too sensitive. I don't think the coil breaks ever (correct me if I'm wrong).
I'm wondering if it would be possible to just mimic the original filling and maybe just redo a used one. Just thinking out of the box, but the knock sensor is just a mic pickup. Just need to make a used one not as sensitive to avoid phantom knock.
I know, easier said than done, but surely it could be done.
1992 Nile black w/sunroof
Posts: 6007 | From: central Indiana | Member Since: 08/06/02 | IP: (192.69.183.60) | Report this post to a Moderator
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1249255 posted 06/30/20 11:17 PM     Remind Me!  Send Private Message   Edit Post
I was thinking that some people have used EVO ecu's in their VR4. Did they switch to an evo knock sensor or use the VR4 OEM one? If the EVO ecu's work with the VR4 sensors it would seem like the reverse would be true if they mount the same way.
Posts: 915 | From: Fremont Ca | Member Since: 03/16/01 | IP: (73.222.214.55) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1249259 posted 07/02/20 04:00 PM     Remind Me!  Send Private Message   Edit Post
I use the evo ecu and had to use a evo knock sensor.
Some of the older Hyundai engines are copy cat designs of the 4g63. Those may still be available from Hyundai.
Who wants to be the ginuea pig and try them??
Just realized that you already know about the Hyundais.
91 GVR4 1450/2000 - 2.3 Stroker - HKS cams
FP3052 - Spal puller - EVO MAF 3"intake - EVO8 560 injectors - EVO8 ECU tephramod v7 - Walbro 255 - F EVO3 exhaust mani - 44mm tial wg
EVO3 5spd
Edited by Eztoril (07/02/20 04:25 PM)
Posts: 70 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:9::78) | Report this post to a Moderator
mk2davis
398/2000
Galant VR-4 org Post #: 1249755 posted 09/22/20 04:17 PM     Remind Me!  Send Private Message   Edit Post
I've had an order with a vendor for a NTK sensor for a couple months now. Initially, the part was reported to be on "national backorder" for 30-90 days.
I received a follow up email stating the part will not be available.
Posts: 157 | From: Ventura, CA | Member Since: 03/01/15 | IP: (47.148.38.75) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.007 seconds were spent on a total of 14 queries. Turbo powered.
