Galant VR-4 Forums » Galant VR-4 » Newbies » New transfer case seal is still leaking
91eagle2000gtx
Newbie
Galant VR-4 org Post #: 1248421 posted 03/04/20 02:21 PM     Remind Me!  Send Private Message   Edit Post
Just replaced my tail seal with a new OEM one about 5 minutes ago and filled the transfer case up with fluid. I turned the input to see how it felt and fluid just started drooling out of the tail. Not sure what to do about it, I slowly hammered it in using some soft wood and it seems to be bottomed out. Any ideas? Thanks
Posts: 5 | From: Saskatoon, SK, Canada | Member Since: 07/26/19 | IP: (216.197.220.42) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1248422 posted 03/04/20 02:30 PM     Remind Me!  Send Private Message   Edit Post
Did you put the driveshaft in? It will leak without the driveshaft
Thom
Posts: 888 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (73.103.0.235) | Report this post to a Moderator
Galant VR-4 org Post #: 1248423 posted 03/04/20 02:30 PM     Remind Me!  Send Private Message   Edit Post
Can you clearly see the leakage point is between the seal lip and the drive shaft itself? You mention a new seal, but are you sure there was no inside lip damage after you tapped it in?
Lastly, it may not need to be put in until it bottoms out. Sometimes a groove is worn in the shaft allowing leakage by the seal and the seal may need to be put in either a little more or less to make sure the new seal lip is NOT aligned with any wear groove.
I am presuming you have the new sealed (recall) yoke design and it is not leaking from there.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Edited by iceman69510 (03/04/20 02:31 PM)
Posts: 10748 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
91eagle2000gtx
Newbie
Galant VR-4 org Post #: 1248424 posted 03/04/20 02:39 PM     Remind Me!  Send Private Message   Edit Post
Yeah the driveshaft isn't in it haha, I'm an idiot. Just waiting for my parts to come in, I bought new carrier bearings, u joints, Lobro Boot kit, and the revised yoke. Should I just fill the t case while it's in the car then? It seemed easier to do while it was out that's all.
91eagle2000gtx
Newbie
Galant VR-4 org Post #: 1248425 posted 03/04/20 02:41 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help and clarification guys, I'm kind of a noob lol. But atleast I'm learning
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1248426 posted 03/04/20 05:05 PM     Remind Me!  Send Private Message   Edit Post
Learning is what its all about. You'll really need to fill it on the car to make sure it has the right amount of fluid. I suggest getting a decent fluid pump to reduce frustration in filling it. Similar to the transmission, you will fill it to the point that it is level with the fill plug, but you don't want to overfill it either.
-254/2000 Summit White DD (aka "The Yeti")
The Yeti loves winter and hates me.
-ムースライジュ
Posts: 1213 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.242) | Report this post to a Moderator
2 registered and 5 anonymous users are browsing this forum.
Generated in 0.072 seconds in which 0.046 seconds were spent on a total of 14 queries. Turbo powered.
