Galant VR-4 Forums » Galant VR-4 » Newbies » #205 checking in for duty
gs300cky
Newbie
Galant VR-4 org Post #: 1242442 posted 04/28/18 10:08 PM     Remind Me!  Send Private Message   Edit Post
Just wanted to introduce myself here, as cory or #205 with my 91 galant vr4. 🤗
Finally picked it up after begging my neighbor to sell it to me.
So far it had exhaust and FMIC installed but nothing else I can tell is aftermarket.
Iím hoping to get it running as the car will turn over after some starter fluid and then it dies after 3-5 sec.
I want to eventually get it cleaned up and simple but sexy, however, for now itís just keeping the sleeper beater look.
Iím looking for help and suggestions though on upgrading the intake and also where to start with this car on diagnosing the engine failure.
Any help and or guidance I appreciate. Iím new to the mistubishi sode of things and have always been Subaru or Hondaís and Lexus.
Guys
I want to die peacefully like my grandpa not screaming like his passengers
Edited by gs300cky (04/29/18 05:50 PM)
Posts: 22 | From: Denver, co | Member Since: 04/24/18 | IP: (168.200.6.5) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 1242443 posted 04/29/18 12:46 AM     Remind Me!  Send Private Message   Edit Post
first thought from your description is the coolant temp sensor that controls cold start enrichment. it's the two pin sensor on the thermostat housing (closed connector, not exposed pins).
My advice: Maintenance before mods.
When you do the timing belt, use a mitsubishi OEM timing tensioner, from the dealer, dont get one from anywhere else.
-Joshua Adventure Driven Design
1991 Galant VR-4
1999 Montero "Goldi-Locker"
Posts: 5593 | From: Arizona | Member Since: 05/28/03 | IP: (2600:8800:2903:b) | Report this post to a Moderator
gs300cky
Newbie
Galant VR-4 org Post #: 1242446 posted 04/29/18 05:53 PM     Remind Me!  Send Private Message   Edit Post
Thank you on that info and yes Iím doing all fluids,belts, hoses and any other small stuff now.
I just did the oil change and plugs next is the gas I want to get rid of and get a new pump as well possibly.
The one thing I also wanted to check was the fuel pump relay behind the glove box but I havenít found him yet.
Posts: 22 | From: Denver, co | Member Since: 04/24/18 | IP: (2601:280:c500:3f) | Report this post to a Moderator
gs300cky
Newbie
Galant VR-4 org Post #: 1242665 posted 05/22/18 10:29 AM     Remind Me!  Send Private Message   Edit Post
[/url]
Edited by gs300cky (05/22/18 10:31 AM)
Posts: 22 | From: Denver, co | Member Since: 04/24/18 | IP: (108.171.132.162) | Report this post to a Moderator
jnava Galant VR4.org Moderator
Galant VR-4 org Post #: 1242671 posted 05/23/18 12:47 AM     Remind Me!  Send Private Message   Edit Post
Also, you'll eventually need to change out that oem maf for a 2g maf as is has a higher range in frequency vs stock. Investing in an eprom socketed ecu and Ecmlink will forever help you on your eventual mods. That being said, as Josh mentioned, maintenance is key.
57/2000
1865/2000
1058*/2000
2000 2.5Gen Montero
2013 Outlander Sport
Posts: 2047 | From: Arlington, Tx | Member Since: 04/18/08 | IP: (2600:1:c5d6:1060) | Report this post to a Moderator
gs300cky
Newbie
Galant VR-4 org Post #: 1242682 posted 05/23/18 11:06 PM     Remind Me!  Send Private Message   Edit Post
So where can I find the 2g mad and wire harness? I was reading about that and I couldnít seem to find the wire harness that swaps it all or computes it.
Plus how can I tell if I have the upgraded parts or the ecmlink ? Sorry for the stupid questions
Galant VR-4 org Post #: 1242686 posted 05/24/18 07:19 AM     Remind Me!  Send Private Message   Edit Post
What that paper tag with the list of criteria is telling you is there is a "Keydiver" chip in the ECU. It says 2g MAS, so you should have a 2g mass airflow sensor on there potentially already.
ECM Link is a newer more capable version of the control system, which also replaces the stock EPROM chip in the ECU with their own version. Open up the ECU box so we can see what's inside, and take a picture of your air flow sensor.
Wire harness adapters are available if you don't already have one on the car.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10745 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
gs300cky
Newbie
Galant VR-4 org Post #: 1248241 posted 01/29/20 11:15 PM     Remind Me!  Send Private Message   Edit Post
Well finally have had more time and weather permitting to work on her (garage without heat sucks to work in)
But thank you iceman for the parts and pieces I bought from you. That has helped ALOT!!!
Now Iím finally feeling Halfway better about turning her on. Just finishing up my new wire harness retape job and cleaning up just a few broken wires otherwise perfect
The left size (interior ecu connections) are complete, now just the main engine bay part left.
Iím going thru regrouping the wires and doing all new tape with TESA tape. So far Iím happy for being my first time. Any advice on things to do while taping and removing my harness let me know.
I already have been going thru and cleaning out the engine bay rust and debris. Not to rusty thankfully just VERY DIRTY.
Posts: 22 | From: Denver, co | Member Since: 04/24/18 | IP: (2601:280:c501:20) | Report this post to a Moderator
gs300cky
Newbie
Galant VR-4 org Post #: 1248303 posted 02/07/20 06:49 PM     Remind Me!  Send Private Message   Edit Post
Almost 100% finished with the new harness and repairs. I have maybe 4 wires to solder on new connectors and figure out where they go.... but otherwise Iím happy with my first harness retape and repair job so far, only 5hours in and another maybe 2 left.
gs300cky
Newbie
Galant VR-4 org Post #: 1248304 posted 02/07/20 06:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
Here was the picture you had asked for previously, although now I replaced it since there was some acid leaking on the circuit board
Galant VR-4 org Post #: 1248314 posted 02/10/20 07:55 AM     Remind Me!  Send Private Message   Edit Post
I was suggesting that we view the chip and label, but there is no chip installed in that picture. Keydiver always had labels on his chips.
0 registered and 45 anonymous users are browsing this forum.
Generated in 0.095 seconds in which 0.034 seconds were spent on a total of 13 queries. Turbo powered.
