Galant VR-4 Forums » Galant VR-4 » Newbies » Rear 3-pont Seatbelt Install
Stevenoly
Newbie
Galant VR-4 org Post #: 1246779 posted 07/31/19 06:57 PM     Remind Me!  Send Private Message   Edit Post
Hi all,
I'm looking to convert my rear outer seats to a 3-point seat belts in my 1988 Galant VR4 (currently have 3 lap belt's back there). I have purchased a set of rear seat belts from one of the part outs, but my question is what is the factory mounting setup on the c-pillar? It it just a stud welded to the body, or is it a plate style that I then thread a bolt into? I've searched the forum and google images to see if I could see a bare c-pillar but have failed so I come to you for help.
Also if anyone happened to have s nice set of c-pillar trim they would part with I wold love to buy a set that already have a hole in them instead of taking the Dremel to mine.
Posts: 10 | From: Mukilteo, WA | Member Since: 04/27/19 | IP: (130.76.24.20) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1246780 posted 07/31/19 09:26 PM     Remind Me!  Send Private Message   Edit Post
it is a nut welded onto the pillar and you mount the pivot bolt here...
Posts: 275 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
Stevenoly
Newbie
Galant VR-4 org Post #: 1246781 posted 07/31/19 09:51 PM     Remind Me!  Send Private Message   Edit Post
Perfect, so just any minimum grade 5 nut and bolt combo, or do I need a specific type of combo? I'm going to take it to a local shop to have the welding done, but want to make sure I have the right parts when I go.
AllanL
Heal and Toe
Galant VR-4 org Post #: 1246783 posted 08/01/19 07:14 AM     Remind Me!  Send Private Message   Edit Post
7/16 x 25mm with lock washer is the bolt size
Edited by AllanL (08/01/19 07:15 AM)
Posts: 275 | From: NV | Member Since: 08/05/08 | IP: (120.29.100.242) | Report this post to a Moderator
Galant VR-4 org Post #: 1246785 posted 08/01/19 08:13 AM     Remind Me!  Send Private Message   Edit Post
Did you get the shoulder belts yet? Typically the seat belt mount bolts are captive in the mounting tab so the correct bolt is used with no mistakes (often because in many import car despite being metric, the thread is SAE as mentioned).
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10856 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Stevenoly
Newbie
Galant VR-4 org Post #: 1246787 posted 08/01/19 09:47 AM     Remind Me!  Send Private Message   Edit Post
After opening the seat belts I see now that there is a bolt mounted in the tab so I need to find the nut that fits. Just for clarification, where does the retractor mount? Looking at it not in the car (and never having been in a USDM car) I知 a bit confused.
I知 grateful for all the help.
Posts: 10 | From: Mukilteo, WA | Member Since: 04/27/19 | IP: (2601:601:9800:19) | Report this post to a Moderator
Galant VR-4 org Post #: 1246790 posted 08/01/19 12:02 PM     Remind Me!  Send Private Message   Edit Post
I would check in your car if the nut is already there. Many times for such a small item, they may make a common panel with the weld nut there.
I can't remember where the retractor is off-hand. Maybe someone has a car apart currently that can take a picture?
Stevenoly
Newbie
Galant VR-4 org Post #: 1246794 posted 08/01/19 02:19 PM     Remind Me!  Send Private Message   Edit Post
I値l try to disassemble some things and see why may be there. As it is a 1988 I知 not sure what I値l find. A picture would greatly help me out if/when someone has time.
Edited by Stevenoly (08/01/19 04:23 PM)
Posts: 10 | From: Mukilteo, WA | Member Since: 04/27/19 | IP: (2607:fb90:b219:7) | Report this post to a Moderator
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.056 seconds in which 0.043 seconds were spent on a total of 14 queries. Turbo powered.
