Galant VR-4 Forums » Galant VR-4 » Newbies » Newb question: fuel pump test connector location/ pic
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1246638 posted 07/20/19 06:38 PM     Remind Me!  Send Private Message   Edit Post
Well, my GVR 4 is nearly ready to fire.
Oil primed, etc.
Drained tank, filled with 5 gal premium.
Figured I would try firing on old gas in line: nope.
I disconnected the AN fitting at fuel rail and it is dry.
I cranked a few times and nothing.
I will swap the fuel filter but wanted to make sure the pump is actually running first?
Can someone explain which is the test plug or post a pic, please?
Thanks,
PJ
#490/1000
Posts: 1555 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (2601:401:4380:74) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1246639 posted 07/20/19 06:56 PM     Remind Me!  Send Private Message   Edit Post
Never mind. Hit it with power at the tank harness and nothing. I have an extra pump so I will swap
#490/1000
138/2000
152/1000
Galant VR-4 org Post #: 1246640 posted 07/20/19 06:58 PM     Remind Me!  Send Private Message   Edit Post
It's on the fire wall by/behind the brake fluid res., I don't /can't get a picture as im not near a vr4 right now.
When you try to start the car do you hear the MPI click? It's a large gold box under the glove box by your ECU, it controls the fuel pump activation.
138/2000
152/1000
Posts: 3671 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (99.203.11.44) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1246642 posted 07/20/19 07:53 PM     Remind Me!  Send Private Message   Edit Post
I will go listen again. Been so long I forgot what that is. (EDIT: Yes, it clicks just after the starter engages. I think that's right.)
However, with the harness unclipped, I'm pretty sure 12V + to black and white and negative to black is whats necessary to run the pump, and the pump is locked up.
I have a Walbro CSS341 NIB sitting here so might as well upgrade from the 190 that was in it.
I had to order a new filter sock though because mine was MIA.
I loosened all the little screws carefully after lots of PB Blaster. However, the main fuel line fitting wont budge.
My neighbor has a MAP gas can so will hit it with that tomorrow.... but not really happy hitting a fitting connected to a gas tank with heat.
Any other suggestions?
Thanks,
PJ
#490/1000
Edited by PJGross (07/20/19 07:57 PM)
138/2000
152/1000
Galant VR-4 org Post #: 1246643 posted 07/20/19 10:46 PM     Remind Me!  Send Private Message   Edit Post
I do mine with vise grips when they won't budge using the 14mm and 19mm, a pair on each fitting.
138/2000
152/1000
Posts: 3671 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1246644 posted 07/20/19 11:38 PM     Remind Me!  Send Private Message   Edit Post
I had vice grips on one, I will crank down on both of them and loosen without heat. I will give the pbblaster some more time too
#490/1000
138/2000
152/1000
Galant VR-4 org Post #: 1246645 posted 07/21/19 12:24 AM     Remind Me!  Send Private Message   Edit Post
I let pb blast soak for 24 hours while hitting it every 4-6.
138/2000
152/1000
Posts: 3671 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (69.36.193.100) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1246650 posted 07/21/19 04:46 PM     Remind Me!  Send Private Message   Edit Post
I put my 14mm flare on, vice grips over it to keep it from spinning, then 3 ft long cheater bars on each side. A little tweak and it was free. Thanks for the input!
Now, do I need to get a new gasket for the fuel pump assembly since it hasn't been apart in 20 years?
-PJ
#490/1000
PJGross
490/1000
Galant VR-4 org Post #: 1246651 posted 07/21/19 05:06 PM     Remind Me!  Send Private Message   Edit Post
Never mind, ordered new gasket for piece of mind. With my luck it would have never gone back on correctly and I'd end up waiting on a new one anyway....
-PJ
#490/1000
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.181 seconds in which 0.167 seconds were spent on a total of 14 queries. Turbo powered.
