Galant VR-4 Forums » Galant VR-4 » Newbies » Water pump outlet pipe. Repair/ replace questions
yeti
Nope still sticky fingers
Galant VR-4 org Post #: 1222515 posted 01/04/16 12:28 PM     Remind Me!  Send Private Message   Edit Post
So I got a pin hole in my water pump outlet pipe the large one that the turbo coolant return line comes out of.
I took it to a friend to get it welded but they said it immediately ran because it was so thin and rusted out. He tryed to patch it but it ended up going soda can thin.
I searched online and could not find a new one at all. I ordered a media blasted used part. Looked clean, all im hoping for is no leaks/rust.
I payed 95$ shipped for this, I tryed a WTB thread but had no luck and just ordered that used one from eBay.
My question is where does everyone else source this water pipe?
~turbohair~
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (97.46.129.196) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1222522 posted 01/04/16 02:04 PM     Remind Me!  Send Private Message   Edit Post
I bought a new NT pipe from JNZ.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:100d:b12c:2) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1222525 posted 01/04/16 02:37 PM     Remind Me!  Send Private Message   Edit Post
Did you have to tap it for the turbo coolant line?
~turbohair~
marvinmadman
136/1000
Galant VR-4 org Post #: 1222537 posted 01/04/16 06:09 PM     Remind Me!  Send Private Message   Edit Post
No. Rearranged the hoses to still run water to the turbo.
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
138/2000
152/1000
Galant VR-4 org Post #: 1222565 posted 01/05/16 07:04 AM     Remind Me!  Send Private Message   Edit Post
hey so you just want the oil cooler port gone?? i have a few pipes and i can cut and weld one to what you need. i just recently did mine as i deleted the oil cooler and FIAV, so i no longer wanted those line in the car. i could pull and clean it today and probably weld it up this afternoon for you. if you don't like what i do you can also not buy it.
138/2000
152/1000
Posts: 3677 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.22.248) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1222576 posted 01/05/16 10:03 AM     Remind Me!  Send Private Message   Edit Post
Sounds as if he's already found what he needed if I read that correctly. Funny yours was rusted out, can't say that I've ever seen a bad one. Good used ones are still around. I usually see them go for $25-$50 with $50 being a bit on the high side IMO.
93 Mitsubishi Expo LRV
95 Eagle Summit DL coupe
98 Mitsubishi Mirage DE coupe
Posts: 2502 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (71.52.131.6) | Report this post to a Moderator
yeti
Galant VR-4 org Post #: 1222588 posted 01/05/16 10:48 AM     Remind Me!  Send Private Message   Edit Post
Correct yes I already ordered this pipe off of eBay.
But definitely good to know can have one fabricated.
I was gonna go to the junkyard and figured they would all be rusty.
Good to know its uncommon for that pipe to rust next time I just search the local yard.
~turbohair~
Posts: 797 | From: san diego california | Member Since: 10/13/10 | IP: (174.240.160.51) | Report this post to a Moderator
Coltsfan
631/1000
Galant VR-4 org Post #: 1222748 posted 01/10/16 10:02 AM     Remind Me!  Send Private Message   Edit Post
I see them rusted out all the time, but I live in Rustville USA. Usually they corrode around the lip that holds the o-ring in place.
92 Galant Vr4 631/1000 ---------DD well on it's way to having new everything...
90 AWD Colt Hatchback ----------Fun car
51 Buick Special ---------------Boring car
Posts: 200 | From: Tonawanda | Member Since: 05/04/14 | IP: (76.180.21.67) | Report this post to a Moderator
1 registered and 19 anonymous users are browsing this forum.
Generated in 0.059 seconds in which 0.048 seconds were spent on a total of 14 queries. Turbo powered.
