I'm lost HELP!!!!!
Ok so I have a 2000 galant and the pulley belt jumped under the timing belt which smashed the sensor, so I changed both belts, camshaft sensor crankshaft sensor also the spark plugs, checked all fuses and there fine, but now I'm stuck the car still wouldn't start!!!!
EfiniX
portland, or
I don't know how much help you'll get here with a, what, 3rd or 4th generation DSM. The VR4 has an E39A motor, so we aren't even looking at the same bits as you.
That being said, check your crank position sensor.
And when you say "won't start", do you mean it's not cranking at all, or it turns over, but doesn't run? Did your timing belt break in all of this mess?
LIV4PSI
O-H-I-O
He has an 8th gen Galant, it's not a 3rd gen DSM /ubbthreads/images/graemlins/rofl.gif
Also, E39A is the chassis code. not the engine code for our cars
