Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Where to find slightly smaller radiator?
thedsmguy
Galant VR-4 org Post #: 967588 posted 02/04/11 12:51 PM     Remind Me!  Send Private Message   Edit Post
I'd like to run a 90% size radiator where the factory one goes keeping a/c but allowing me to run intercooler pipes on the side of the ac condenser and radiator. Factory size you would run into the radiator on the pass side so maybe someone knows of a different cars radiator or where to buy a aftermarket that is just a few inches less wide. I'd rather stay away from spending $300-400 if at all possible. I know a lot of people run the civic race style but I guess I'm really hoping someone will chime in with go find a "x" in the junkyard it will work with just a little fab work.
Thanks.
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (76.115.75.147) | Report this post to a Moderator
OMFGeofffff
All I want is a dodgy
567/1000
Galant VR-4 org Post #: 967599 posted 02/04/11 01:40 PM     Remind Me!  Send Private Message   Edit Post
I've heard of getting the core modified by removing a few of the columns so it's narrower.
-Jeff
Kensington Grey - A87 stock (EQ/input, no sunroof)
XBL - uh oh its JEFF
Posts: 867 | From: Burnsville, MN | Member Since: 05/05/06 | IP: (216.147.163.29) | Report this post to a Moderator
Galant VR-4 org Post #: 967625 posted 02/04/11 03:13 PM     Remind Me!  Send Private Message   Edit Post
Quoting thedsmguy:
Thanks.
I don't know of a radiator that will work, but I am intending to do pretty much the same thing in a slightly different way. I'm using a Griffin core with inlet and outlet on your passenger side. I intend to fabricate new A/C condenser lines and because I will no longer need the driver side intercooler inlet I am going to move the radiator over far enough to make way for the intercooler piping. If you have a traditional core however this probably won't be an option. Just throwing that out there.
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (116.48.4.133) | Report this post to a Moderator
bustedsm
trying to feel really special
Galant VR-4 org Post #: 967730 posted 02/04/11 10:44 PM     Remind Me!  Send Private Message   Edit Post
Scirroco radiator....check my build thread, you'll see why
2006 Kawasaki ZX-6R 636 - Raw Plasma Candy Blue
Posts: 844 | From: Ripley, Tennessee | Member Since: 11/30/06 | IP: (70.130.179.79) | Report this post to a Moderator
Galant VR-4 org Post #: 967732 posted 02/04/11 10:56 PM     Remind Me!  Send Private Message   Edit Post
It is a great mod and one I would like to do, but like myself the OP says he wants to keep the A/C which makes using the Scirocco Radiator more difficult because it sits where the A/C condenser usually goes.
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 967748 posted 02/04/11 11:59 PM     Remind Me!  Send Private Message   Edit Post
On my last Colt with a 4G63 swap I grabbed a radiator from a 90 Audi A100 at the junkyard. It fits down in the radiator support like the scirocco one but you should be able to mount it behind the AC condensor as well in the stock location. There is also one pic showing how I had the IC piping ran when I had the civic radiator but I was able to run it the same way with the Audi one however I don't have its exact measurements.
Edit: Autozone's site actually lists the measurements for both.
Audi A100- 24 1/8" x 12 1/8" x 1 1/4"
Galant VR-4- 26 1/4" x 14 3/4" x 1 1/4"
Edited by 89Mirageman (02/05/11 12:08 AM)
Posts: 2501 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (76.3.196.33) | Report this post to a Moderator
Galant VR-4 org Post #: 967753 posted 02/05/11 12:24 AM     Remind Me!  Send Private Message   Edit Post
Nice!!!
I might need to look into that as well. Thanks.
thedsmguy
Galant VR-4 org Post #: 967765 posted 02/05/11 02:19 AM     Remind Me!  Send Private Message   Edit Post
Thats the best option I've seen lately. I was going to go junkyard searching in the next day or two as well!
475/1000
Galant VR-4 org Post #: 967804 posted 02/05/11 11:53 AM     Remind Me!  Send Private Message   Edit Post
The audi's sciroccos and the passats from the early 90's all have the same layout. I'm using a scirocco radiator then a passat fan with the double fan with one motor. It took some work to make it fit and used VW fan mounting tabs to work but all went together and fabbed up sheetmetal shields over the endtanks. The passat radiator is just a few inches longer than the scirocco.
Now what i was thinking other day for my water to air setup is that I'll just use a passat radiator in front of my scirocco. 3 times the size of the normal water to air exchanger, more volume and I'll be able to easily seal the two together, which will help on cooling because the fans kick major tail. Now as for fans the passat from the early 90's had no grill so the fan pulls certious rpms and volume but the motor is two stage and long. the corrados from the same time had the same style fan but the fan motor is super low profile. I've just never found one in a junkyard yet and most ebay sellers know what they have and want sell just the motor off the setup.
Just looked and no corrado factory assembly on ebay but found this which is a smoking deal and the same one I have. Top to bottom fits perfect on a scirocco but the sides are just a little long and requires just some small tabs with nuts and bolts. I used nissan taillight gooey weatherstrip stuff to seal the tops and bottoms and has never gave any problems. Only thing with this the fan motor is long and the turbo inlet tube has to be angled back towards the trans then up but I had a s362 with a 4 inch intake pipe and it fit so just about any combination of turbo will work.
click me
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.114) | Report this post to a Moderator
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.216 seconds in which 0.192 seconds were spent on a total of 14 queries. Turbo powered.
