Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Vr4 coilovers on a zr4?
galantgti
Galant VR-4 org Post #: 1249855 posted 10/11/20 04:49 AM     Remind Me!  Send Private Message   Edit Post
How do you guys think about putting vr4 specific coilovers on a zr4? I mean, there's a difference in weight, dynamics and dimensions between the two. Would the rear coilovers do for the hatchback as well?
1989 Galant GTi-16v White 145hp
1992 Galant GTi-16v Black 144hp RIP
1978 Buick Skyhawk 3.8 V6 110hp RIP
1997 Galant GLXi 136hp Green RIP
2000 Opel Omega 2.5 V6 Irmscher 208hp RWD
1991 Galant zr4
Posts: 106 | From: netherlands | Member Since: 06/19/15 | IP: (2001:1c05:3604:e) | Report this post to a Moderator
Galant VR-4 org Post #: 1249860 posted 10/11/20 03:54 PM     Remind Me!  Send Private Message   Edit Post
You put the desired spring rates in based on the difference in weight. There is no zr4 in the usa. Iíve no idea what your talking about. If itís awd it probably has the same rear subframes and upper rear strut mounts are pretty universal for most Mitsubishi cars. Coilovers are usually height adjustable depending on which you get. What issue are you expecting to run into?
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (173.52.119.128) | Report this post to a Moderator
galantgti
Galant VR-4 org Post #: 1250003 posted 11/10/20 05:32 PM     Remind Me!  Send Private Message   Edit Post
It's the hatchback version of the vr4. Bit beefier and heavier on the back.
My main concern was the weight difference. I was wondering if the extra 75 kg constantly was worth an extra concern or that it doesn't matter so much. Would it cause extra wear per example ?
1991 Galant zr4
Galant VR-4 org Post #: 1250029 posted 11/15/20 07:49 AM     Remind Me!  Send Private Message   Edit Post
extra wear, no. The desired spring pressure should be calculated for additional weight. That should be all.
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1250034 posted 11/15/20 10:53 PM     Remind Me!  Send Private Message   Edit Post
75 kg and a slight difference in CG shouldn't be an issue. You can experiment with little increases in rear spring preload and damping to get it feeling a bit firmer as needed.
Posts: 1966 | From: Marysville, WA | Member Since: 04/25/07 | IP: (2601:601:9900:6d) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1250081 posted 11/23/20 04:01 PM     Remind Me!  Send Private Message   Edit Post
You will be fine. Close enough.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 798 | From: Corona, CA | Member Since: 04/08/08 | IP: (76.94.44.169) | Report this post to a Moderator
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.02 seconds in which 0.011 seconds were spent on a total of 13 queries. Turbo powered.
