Best Place to Source Quality Brakes
iceman69510  Turn Right Racing 855/2000
posted 12/07/20 06:51 AM
Quoting vr4g63tcs:
Are you on a single piston setup? Stainless steel brake lines?
I would recommend doing dual piston, make even from an 05 outlander.
Unless someone messed with this car, Galant VR4s came with dual piston front calipers and 276mm front rotors.
Outlander front calipers (if you get the mounting brackets) do enlarge the rotor and brake envelope, so it may require larger wheels. FWIW, the Outlander caliper bodies themselves are essentially the same as 2G Eclipse AWD, and the piston size is only about 1mm larger diameter then the GVR4 caliper pistons. The mounting brackets are what make the difference. So if you upgrade you won't get much benefit unless you do use the larger rotors as well.
I just this summer rebuilt a pair of GVR4 front calipers and a pair of '05 Outlander calipers, so pretty familiar with them (hose attachment style is different as well). I plan to use the Outlander brakes on my 98 Eclipse GST.
91 VR4 855 Nile Black 92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10818 | From: Michigan | Member Since: 03/05/01 | IP: (76.204.115.93) |
