Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Aftermarket rear engine mount (roll stop)
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1248101 posted 01/06/20 05:43 PM     Remind Me!  Send Private Message   Edit Post
Figured I should put this here to have it documented
Installed the prothane engine roll stops in my car while it was down getting the trans rebuilt. Car no has a cruising vibration from 2-2.5k-ish rpm, probably due to the balance shaft elimination (bse). Replaced the front with an aftermarket mount and didn't change anything. I am in the process of changing out the rear with part number 8105 (it is listed like this if you go to rockauto, AutoZone, etc.), It also the same one listed for the eclipse gsx. The problem is that it is too tall (by one inch) and curved towards the firewall. Searching dsmtuners click they say it's for a fwd. Awesome...
I guess I will just live with it until I can source a stock replacement. Also, I am assuming that it's NLA (MB436495)
Posts: 411 | From: Murray, KY | Member Since: 10/10/12 | IP: (65.114.124.124) | Report this post to a Moderator
Galant VR-4 org Post #: 1248105 posted 01/07/20 08:59 PM     Remind Me!  Send Private Message   Edit Post
Yes, the FWD version is taller. I remember running into this when I put a FWD engine into my 2nd VR4. Part of the reason the bracket is also different.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10775 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1248110 posted 01/08/20 08:28 AM     Remind Me!  Send Private Message   Edit Post
Iceman, do you know if you could use the rear bracket from a fwd and the fwd mount to make it fit?
And a confirmation on the mount through Mitsubishi being NLA, in the us at least (I am still waiting to hear back from JNZ to find out if there is any globally).
Galant VR-4 org Post #: 1248111 posted 01/08/20 11:48 AM     Remind Me!  Send Private Message   Edit Post
I don't think that works. I believe it is the crossmember that is different as well requiring the other parts to match.
Posts: 10775 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1248121 posted 01/09/20 07:47 AM     Remind Me!  Send Private Message   Edit Post
no chance the press the bushing out of the FWD bracket and press it in the 4WD bracket?
Posts: 270 | From: NV | Member Since: 08/05/08 | IP: (120.29.100.236) | Report this post to a Moderator
Galant VR-4 org Post #: 1248131 posted 01/09/20 08:44 PM     Remind Me!  Send Private Message   Edit Post
Good idea.
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1248150 posted 01/12/20 02:55 PM     Remind Me!  Send Private Message   Edit Post
Quoting AllanL:
I haven't tried, but people doing it in the past said "the sleeves on the aftermarket ones just crumble when you try."
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.024 seconds in which 0.011 seconds were spent on a total of 13 queries. Turbo powered.
