Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Replacement clutch pedal lever bushing
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1247510 posted 10/14/19 05:40 PM     Remind Me!  Send Private Message   Edit Post
Rebuilt the entire clutch pedal assembly a few years ago but looks like that plastic bushing where the master cylinder clevis pin goes through ate it up already as I have some initial slop.
Anyone find a drop in bronze bearing for that slot? Or anything else that would work, even if its plastic I suppose because not like its hard to replace.
GVR4 1242/2000
Edited by cupajoe (10/14/19 05:47 PM)
Posts: 336 | From: Lake Mary, FL | Member Since: 03/01/10 | IP: (184.90.132.33) | Report this post to a Moderator
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1247511 posted 10/14/19 08:14 PM     Remind Me!  Send Private Message   Edit Post
Nevermind, I went to Lowes and picked up a bronze bushing. Cut it in half, drilled out the center diameter a bit to fit the clevite pin, used the dremel to shave down the outside diamter enough to fit into the pedal lever. Greased, slipped in, and zero play now. GG.
GVR4 1242/2000
Galant VR-4 org Post #: 1247515 posted 10/15/19 07:25 AM     Remind Me!  Send Private Message   Edit Post
Just FYI, I believe the clevis pin does have a spec for some freeplay so as to not keep a load on the cylinder. I would have to check the manual again to be certain.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10747 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1247516 posted 10/15/19 08:32 AM     Remind Me!  Send Private Message   Edit Post
Agreed, there should be some "dead space" when you start compressing the clutch, I still have this and I did make sure to not have any pressure loaded when I threaded in the master.
My issue was I had to MUCH play, lol turns out my bushing was toasted and missing.
GVR4 1242/2000
0 registered and 43 anonymous users are browsing this forum.
Generated in 0.278 seconds in which 0.259 seconds were spent on a total of 14 queries. Turbo powered.
