Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Fan sensor 1/8" bsp?
Galant VR-4 org Post #: 1247037 posted 08/27/19 09:30 PM     Remind Me!  Send Private Message   Edit Post
I need a sensor to kick on a fan relay. The only extra port I have on the thermostat housing is the one next to the heater core port on the back. I'm pretty sure its 1/8" bsp, right? Anyone know where I can get a 185* sensor that size? I'd tap it to npt but its already installed and I don't think I have the room.
The galant had a stock sensor in this spot that triggered both fans as a failsafe I believe. I think that sensor is a higher temp though. IDK. Can anyone confirm that?
I need a two wire sensor because I wired the relay already for positive trigger.
So 2 wire 1/8" -28 bspt 180 on 165 off fan switch. Anyone?
Edited by tektic (08/27/19 11:19 PM)
Posts: 1482 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
Galant VR-4 org Post #: 1247078 posted 08/29/19 07:32 AM     Remind Me!  Send Private Message   Edit Post
What about the drain port in the radiator? I have a civic half rad. Anyone know the thread size on those? That would be easy enough to wire.
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1247082 posted 08/29/19 10:23 AM     Remind Me!  Send Private Message   Edit Post
Easiest may be to use a bsp to npt adapter?
I found a place in Australia, but it was a sensor not a switch.
-PJ
#490/1000
Posts: 1555 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (204.117.38.42) | Report this post to a Moderator
Galant VR-4 org Post #: 1247107 posted 09/01/19 08:48 AM     Remind Me!  Send Private Message   Edit Post
Where do I find a replacement wire connector for the stock white fan sensor? It is 2 pin oval and has the two notches @ 4 and 8 o'clock.
1 registered and 30 anonymous users are browsing this forum.
Generated in 0.325 seconds in which 0.315 seconds were spent on a total of 14 queries. Turbo powered.
