Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » ABS light on after long storage, new SS brake lines installed
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1246686 posted 07/24/19 03:05 PM     Remind Me!  Send Private Message   Edit Post
I replaced rear calipers and added SS brake lines all around while car was down.
I bled the entire system and brake pedal was very firm.
Car was down for years, so could be corrosion on rings?
I started up car today and brakes felt normal, but the ABS light is on along with the brake light.
Suggestions? I did do a search but nothing came up.
-PJ G.
#490/1000
Posts: 1555 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (2601:401:4380:74) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1246688 posted 07/24/19 06:34 PM     Remind Me!  Send Private Message   Edit Post
Probably air in the abs pump. Try activating the abs on loose gravel and then re-bleed. If it will activate. Not sure if the light being on will disable the abs.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1246689 posted 07/24/19 07:04 PM     Remind Me!  Send Private Message   Edit Post
Got a dirt road right by the house. Will try it Saturday.
I just got insurance put back on it today, but can't get to secretary state for a few days to get a new tag.
Thanks for the tip!
-PJ
#490/1000
JDM Unit
486/1000
Galant VR-4 org Post #: 1246694 posted 07/24/19 09:12 PM     Remind Me!  Send Private Message   Edit Post
Let us know if the abs is disabled when the light is on, clean abs hack!
www.nostalgic.co.jp
PJGross
490/1000
Galant VR-4 org Post #: 1246698 posted 07/25/19 08:39 AM     Remind Me!  Send Private Message   Edit Post
Procedure to bleed the ABS unit itself? Is there a VFAQ for this?
I did not do this. I only bled brakes at the corners.
#490/1000
Posts: 1555 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (204.117.38.42) | Report this post to a Moderator
Galant VR-4 org Post #: 1246699 posted 07/25/19 08:47 AM     Remind Me!  Send Private Message   Edit Post
I don't believe there is a special procedure for bleeding ABS on this car. I use a vacuum bleeder on mine usually, and have not had issues.
I would check for junk (usually metallic) collected on the front sensor magnets. This can affect the reading.
Sitting for a while it may be a stuck solenoid in the unit itself. Clean fluid and driving it to get the system to activate is a good starter approach. Hopefully if this is it, it will break loose.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10770 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Galant VR-4 org Post #: 1246700 posted 07/25/19 08:48 AM     Remind Me!  Send Private Message   Edit Post
If you end up needing a hydraulic unit (if you keep ABS), I think I have one in my collection.
PJGross
490/1000
Galant VR-4 org Post #: 1246704 posted 07/25/19 09:30 AM     Remind Me!  Send Private Message   Edit Post
My dirt road is bumpy, too! That could help.
I will also see if I can clean the rings. I could have bumped the sensor on one of the corners as well. I changed out the passenger front half shaft when it was JSBing so I can start there after a quick drive on the road.
Need to get my registration updated. Last tag I had was 2008. Saved over a grand in tag costs that way, at least.
-PJ
#490/1000
Galant VR-4 org Post #: 1246706 posted 07/25/19 09:58 AM     Remind Me!  Send Private Message   Edit Post
I am planning to use the specific year plate program in Michigan when (if?) I get mine back on the road this year. I have a nice pristine 91 blue plate for it.
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1246793 posted 08/01/19 12:10 PM     Remind Me!  Send Private Message   Edit Post
Delete the ABS IMO. The stuff on our car is 2 channel diagonal garbage, and it barely helps if you brake like a monkey mid corner in the rain. In every context of using brakes properly it simply increases your stopping distance due to the glacial cycle rate.
If I had an Evo, I'd keep ABS, but on these shitpiles, it's a liability. I measured a ~25' shorter stopping distance from 60-0 with some very fast & loose methods, but it was pretty consistent.
The junk is heavy, doesn't work well, and makes the engine bay look like crap. Plus now I have an awesome location for my remote oil filter setup
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3712 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (192.195.4.32) | Report this post to a Moderator
Generated in 0.475 seconds in which 0.446 seconds were spent on a total of 14 queries. Turbo powered.
