EgonOlsen
I imported the car from norcal this summer and it has some issues that needs fixing. Mostly small stuff...I hope.
Im not a mechanic and I knew nothing about cars before I started on this(or very little) so noob questions will be plenty.
Mods as per seller:
1. Evo 3 hotside and manifold.
2. SS fuel lines and Clutch line
3. Megan tubular O2 and 3" downpipe/exhaust.(its stock exhaust, no 3' only downpipe.)
4. Modified ECU with Ostrich for SD setup.
5. IAT sensor and 3bar gm Map.
6. FIC80(860cc) injectors.
7. Fresh rebuilt 1G trans.
8. Upgrade 1g shifter setup w/ Symbroski bushings.
9. The front end is full Energy Suspension bushings.
10. Upgraded big brake mod up front
11. Has brand new G2 struts in the fronts and AGXs in the rear.
12. 255 fuel pump.
13. Previous seller should have done rebuild on engine.
Included in sale should be:
1. ACT2600 Clutch new.
2. GR2 for the rear, New.
3. Stock ECU (fresh rebuild) (havent found that 1, seems missing)
Done before shipping:
1. New clearcoat on entire car. Done
Needs doing now:
1. Needs I/C installed, had a hotpipe that didnt come with the car. Need stock I/C installed. Have parts. Done
2. Battery is dead, New Odyssey PC680MJ have been ordered.
3. Manual windows in front doors, power windows need to be installed. Done
4. 1 headlight have broken some plastic on the ajusters on the back. Installing EDM headlights, need adaptors for H4, plugs ordered.
5. all interior trim(plastics) is removed. Need it all installed again. Have parts.
6. Carpet and rooflining missing as well, have pieces, needs installed.
7. 3' downpipe, 2' catback(stock) cat missing. Need cat and reducer installed. 3' cat + reducer ordered from Tunersnation.
8. A/C installed again. Have parts.
9. Backseat top is dried out and ripped. Need another backseattop.
10. Washer resevoir+motor missing. Needs installing, Have part. Done
11. Both foglights cracked. Need new ones.
12. Front blinkers missing, part bought.
When all this is done and its running its time to make sure everything is in order and do maintaining.
Future plans:
1. Bigger I/C
2. Mishimoto Alu Radiator installed. Have part. Done
3. ACT2600 Clutch installed. Have part.
The pictures are sellers + when I picked it up at the harbor.
Pictures I took after recieving:
Mods as per seller:
12. 255 fuel pump.
Needs doing now:
Future plans:
1. Bigger I/C
