Galant VR-4 Forums » Galant VR-4 » Technical Discussions » another ABS question
sleepr4
Galant VR-4 org Post #: 997857 posted 06/07/11 05:19 PM     Remind Me!  Send Private Message   Edit Post
so as im driving when i slow down to a stop my abs kicks in for some reason and im driving normal and it makes me scared that its notngona stop because it makes a grinding noise, but then some days my abs light goes on and then it doesnt do it...anyway to not make the abs kick in? idgaf about the light being on
| | | IP: (98.223.136.130) | Report this post to a Moderator
AnotherNewb
flutterdumper
Galant VR-4 org Post #: 997952 posted 06/07/11 11:46 PM     Remind Me!  Send Private Message   Edit Post
Remove the abs fuses and unhook the plugs from the abs pump. Also look for a non abs conversion for sale and drop the 19lb boat anchor from your left front.
Every terrorist killed is a victory for Wookalar
Posts: 1470 | From: Orlando, FL | Member Since: 04/26/10 | IP: (174.252.195.103) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 997964 posted 06/08/11 12:36 AM     Remind Me!  Send Private Message   Edit Post
Quoting sleepr4:
I spent a couple hundred bux trying to trace the same problem in mine. Ultimately it was fixed by being removed to the round file. Situation almost caused two separate accidents.
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (76.176.152.126) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 997974 posted 06/08/11 01:00 AM     Remind Me!  Send Private Message   Edit Post
I've had the same thing happen and yes its very scary. The ABS is horrible and poorly engineered in these cars so your best bet is to pull the fuse on the battery cable fuse block and or completely remove it cause its not worth trying to fix
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (75.206.75.16) | Report this post to a Moderator
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1000239 posted 06/18/11 03:07 PM     Remind Me!  Send Private Message   Edit Post
Do I have to remove both fuses?
852/2000 (sold
436/1000 (sold
Wtb another vr4 pm me
Posts: 199 | From: Chino Hills, California | Member Since: 12/02/10 | IP: (208.54.39.221) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 1000258 posted 06/18/11 04:20 PM     Remind Me!  Send Private Message   Edit Post
Just the main fuse on the battery fuse block will disable the system. to shut the light down you need to unplug the abs module mounted in the trunk (drivers side by the antenna motor, under the side liner). this will take the ABS out of play.
To do a proper full on abs delete you'll need front hard lines from a non abs eclipse or lower trim level galant. I used a brake proportioning valve from a 3000gt but others will also work. Ideally use one from a four wheel disk car to maintain the front rear brake bias.
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (75.37.164.150) | Report this post to a Moderator
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1000374 posted 06/19/11 01:22 PM     Remind Me!  Send Private Message   Edit Post
thanks ,going to try it later today.
852/2000 (sold
436/1000 (sold
Posts: 199 | From: Chino Hills, California | Member Since: 12/02/10 | IP: (76.174.199.89) | Report this post to a Moderator
2 registered and 71 anonymous users are browsing this forum.
Generated in 0.133 seconds in which 0.106 seconds were spent on a total of 14 queries. Turbo powered.
