Auto Transmission Issues, Overdrive/End clutch
thedsmguy
Vancouver Washington
Ok, So I replaced the end clutch disks on this awd laser that I have. It is still slipping or plain not engaging overdrive.
Any suggestions? The disks I pulled out were toast so I thought by putting new steels/clutches it would be a easy fix
Thanks.
Rausch
Cleveland, OH
^ Fluid pressure issues?
Bad solenoid? (I need to go look at an exploded view of this trans again.)
No other symptoms?
Have another valve body lying around that is a known good part?
thedsmguy
FYI Turns out I grabbed a end clutch from a 91 tranny assuming it was the same as the 93, My brother swapped them without noticing that the 91 had a much larger diameter seal on the end and that was leaking all our fluid out. Once I found the right seal for it, its back to working correctly.
