Rock pistons and cyl wall question
thedsmguy
Vancouver Washington
I have a chance to buy a "shop" rebuilt factory spec bottom end for a pretty cheap price. Question is, are "rock" pistons worth a crap and one of the cyl walls has a up/down "scratch" in the cyl wall, if you run your fingernail over it it will catch lightly. I would think that this would still run fine the motor spins freely etc. Any input would be awesome.
Thanks.
The_Big_Weave
Rapid City, SD
If it was rebuilt they should have bored and honed the cyl and you should not feel anything it should be smooth.
TylerAdamson
Iowa City, Iowa
If you're fingernail is catching it then it wasn't machined properly. I would not run the motor
usually when boring a block the boring bar leaves a vertical line in the cylinder. it should go away when the cylinders are honed. if its still visible, and worse, you can feel it, then the machine shop messed up.
alansupra94
Wayne,NJ
You should definitely not be feeling anything on those walls. Seeing the crosshatching is a different story.
Muskrat
Lexington, KY
^1 on what's been said.
1) It's a stress riser.
2) It's a heat riser.
When/if that block fails, I bet it cracks in that groove. I'd stay away from it. No reason to buy a questionable block, unless you plan to bore it out anyway.
thedsmguy
Ok.. The weird thing is that its not a true strait up and down line. Sorta goes sideways a little almost like it was put(or happened) after it was honed etc. I'll just pass on it I guess.
thedsmguy
I pulled the piston out of that block today. The bottom (oil scraper) ring had its "middle" part basically overlapping itself. I went to a machine shop and they suggested emmory cloth and a ball hone and let it rip.
Anyone see any problems? The scratching really wasn't super deep.
