Galant VR-4 Forums » Galant VR-4 » Technical Discussions » fuel pump not priming with key on.
RichHenry
Galant VR-4 org Post #: 945052 posted 10/31/10 10:28 PM     Remind Me!  Send Private Message   Edit Post
s this is an odd one i cant seem to put my finger on. the past few days my cars been having a hard start. and i have to keep it running for about 3 mins before i can even begin to think of letting off the throttle to let it idle. it only does this when its been sitting awhile. so anyway. i aheva wally 255 in my car. and i noticed today, that it isnt priming anymore when i turn the key to the on position. but if i jog the key i hear it kick on and shut off when the car stalls. i know this is my problem as my car has no fuel pressure for the first minute and once the psi stablilizes. my car runs flawlessly. does anyone know what it could be? i doubt its a relay... but it is a possibility? any suggestions are appreciated.
| | | IP: (68.36.116.116) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 945074 posted 10/31/10 10:51 PM     Remind Me!  Send Private Message   Edit Post
Pump only turns on when the engine is spinning. It doesnt work like a Honda.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (70.189.17.249) | Report this post to a Moderator
RichHenry
Galant VR-4 org Post #: 945216 posted 11/01/10 09:32 AM     Remind Me!  Send Private Message   Edit Post
hmm well then im curious as to why im having such hard starts when it sits awhile
Key Fob Guy
Galant VR-4 org Post #: 945217 posted 11/01/10 09:35 AM     Remind Me!  Send Private Message   Edit Post
Quoting marvinmadman:
^ This is correct.
Does your car still have all the "cold start" mechanisms? i.e. ISC/FIAV
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 945227 posted 11/01/10 09:46 AM     Remind Me!  Send Private Message   Edit Post
How long do you have to crank the car before it starts? I think we should consider other things besides fuel pressure. Have you actually measured fuel pressure with a gauge? Or are you just guessing?
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.185.58.90) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 945231 posted 11/01/10 09:56 AM     Remind Me!  Send Private Message   Edit Post
If you have an aftermarket AFPR or fuel pump, maybe it's just leaking down and has to build up pressure again the next time it cranks.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
Struc
Not all filled in
Galant VR-4 org Post #: 945236 posted 11/01/10 10:06 AM     Remind Me!  Send Private Message   Edit Post
Quoting steveGLS:
^ This is correct.
I'm not saying my car isn't fruity or something, but my fuel pump cycles whenever I turn the car to the "on" position. Stays on for about 5 seconds or something like that.
Curt Shambeau
92 GVR4 56/1000 (SOLD)
09 Lancer Ralliart (SOLD)
96 Spyder GS(t) (SOLD) - My 4G64 Spyder Website
1987 Montero SWB (Wideblock 4g64 build in progress)
Posts: 764 | From: Oconomowoc, WI | Member Since: 11/24/08 | IP: (65.29.40.178) | Report this post to a Moderator
RichHenry
Galant VR-4 org Post #: 945238 posted 11/01/10 10:10 AM     Remind Me!  Send Private Message   Edit Post
barnes. yes the FPO IS set i set it at work its 37 with teh vaccum line hooked up IIRC. all of the cold start items are hooked up. it jsut started doing it the day after i broke a wire off my o2 sensor plug and replaced it with another.. coincidence? as for having to crank it. i can get in it and it will crank for a good 15 seconds. but if i jog the key twice itll start up immediately the third time. then stall. i keep doing that while giving it throttle to keep it running. and it bogs badly when i give it any decent throttle. but once its running for a good minute. its perfect... idles perfect everything. im lost.
Key Fob Guy
Galant VR-4 org Post #: 945240 posted 11/01/10 10:14 AM     Remind Me!  Send Private Message   Edit Post
I think theres a coolant temp sensor that can go bad, causing startup issues?
-mitsuturbo
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 945243 posted 11/01/10 10:19 AM     Remind Me!  Send Private Message   Edit Post
Well, what I mean Rich, is have you actually watched the fuel pressure gauge as you are trying to start the car? This would actually require two people, but you see what I'm asking. This almost sounds like a bad coolant temp sensor to me.
-Jon Barnes
#237/2000 White
RichHenry
Galant VR-4 org Post #: 945245 posted 11/01/10 10:23 AM     Remind Me!  Send Private Message   Edit Post
well the temp sensor appears to be working. ill definitely give that a look. and barnes. no i didnt. i have a matco fp gause i manually hooked up. im heading to work to hook my 4 ws back up. when im there ill test my coolant temp sensor and check my FP during crank.
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 945251 posted 11/01/10 10:38 AM     Remind Me!  Send Private Message   Edit Post
Just remember these cars have like 3 temp sensors. One for the dash gauge, one for the ECU, and one for the A/C. So your dash gauge could work great, but the temp sensor for the ECU could be dead. Let us know what you find out.
-Jon Barnes
#237/2000 White
RichHenry
Galant VR-4 org Post #: 945298 posted 11/01/10 12:53 PM     Remind Me!  Send Private Message   Edit Post
ok manb thanks. ill look it up in all data and get back to you about how i made out.
RichHenry
Galant VR-4 org Post #: 945357 posted 11/01/10 04:15 PM     Remind Me!  Send Private Message   Edit Post
Well. Problem solved. It was the coolant temp sensor. I guess when I tugged the o2 wire it broke one of the wires on the two blade sensor. I repaired it and all of my issues are gone. Thanks for the help to all whom contributed
| | | IP: (208.54.90.49) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 945390 posted 11/01/10 06:35 PM     Remind Me!  Send Private Message   Edit Post
Does your fuel pump prime with the key in the on position again?
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
RichHenry
Galant VR-4 org Post #: 945460 posted 11/01/10 08:33 PM     Remind Me!  Send Private Message   Edit Post
nope. must hae never done it in the past. i just assumed it did since i am used to hondas.
marvinmadman
136/1000
Galant VR-4 org Post #: 945468 posted 11/01/10 08:38 PM     Remind Me!  Send Private Message   Edit Post
Hence my first reply. I have to jiggle the key in my civic everyday cause the main relay kicks off my fuel pump on the highway.
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Key Fob Guy
Galant VR-4 org Post #: 945528 posted 11/01/10 11:36 PM     Remind Me!  Send Private Message   Edit Post
Quoting RichHenry:
OMG. Score one for me in the Tech section?
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (76.6.42.80) | Report this post to a Moderator
RichHenry
Galant VR-4 org Post #: 945600 posted 11/02/10 09:19 AM     Remind Me!  Send Private Message   Edit Post
well you did say it first...
spoulson
0 people like this
Galant VR-4 org Post #: 945611 posted 11/02/10 09:30 AM     Remind Me!  Send Private Message   Edit Post
Quoting steveGLS:
Shawn Poulson*
  ʇuɐlɐƃ ɐ suʍo ɹǝƃuol ou *
Posts: 2907 | From: Middletown, DE | Member Since: 02/05/03 | IP: (63.113.210.11) | Report this post to a Moderator
0 registered and 26 anonymous users are browsing this forum.
Generated in 0.197 seconds in which 0.138 seconds were spent on a total of 14 queries. Turbo powered.
