Galant VR-4 Forums » Galant VR-4 » Technical Discussions » weird knock issues
weird knock issues
BoostedAWD91
815/2000
Galant VR-4 org Post #: 928836 posted 09/07/10 06:48 PM     Remind Me!  Send Private Message   Edit Post
Every once in a while while cruising my knock gauge spikes while on about 20% throttle. I'd let off and go again and everything would be fine for awhile. Just now it started doing it again every time I hit the throttle why cruising for about a min or two straight. I'm running v3 w/ evo 8 mad, I don't see any obvious problems taking a quick glance. Any ideas?
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (75.206.224.146) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 929630 posted 09/09/10 06:47 PM     Remind Me!  Send Private Message   Edit Post
Any thoughts
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (75.206.188.171) | Report this post to a Moderator
Hult250R
Galant VR-4 org Post #: 929797 posted 09/10/10 07:57 AM     Remind Me!  Send Private Message   Edit Post
It sounds like phantom knock. Knock sensor is picking up a noise from somewhere else in the engine. Could be lifter tick, a power steering pump rattling, pretty much anything that's making a sound in the knock sensors sound frequency window.
I had the same problem with my 1G. I ended up having keydiver burn a chip with a phantom knock code in it to ignore any knock under 80% or so throttle position. I've since had another motor built and don't have that problem with this motor
I've got DSMLink now, its got a setting in it for phantom knock as well. I just can't remember exactly where the setting is. You may want to look into the DSMLink wiki and see if that may help.
| | | IP: (68.171.231.19) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 929922 posted 09/10/10 06:49 PM     Remind Me!  Send Private Message   Edit Post
Yea I never thought about that. Ill have to check around v3 when I get back
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (75.206.103.3) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.061 seconds in which 0.05 seconds were spent on a total of 14 queries. Turbo powered.
