Galant VR-4 Forums » Galant VR-4 » Technical Discussions » ABS cv joint/axle?
ABS cv joint/axle?
fastasleep
I love first-timers.
197/2000
Galant VR-4 org Post #: 877306 posted 02/24/10 10:57 PM     Remind Me!  Send Private Message   Edit Post
So, ever since I changed my CV joint (axle) on the front passenger side, my ABS would freak out, so I just unplugged it and have been living without it for quiet some time. A friend of mine commented that I probably didn't get an "ABS axle," which is causing my ABS sensor (vehicle speed sensor?) to freak out.
Is this a possibility? Is there even such a thing as an ABS axle that could cause my ABS to wig out?
Ben
197, Evo 3 Powered
Isaiah 43:4
Posts: 1779 | From: Christiansburg, VA | Member Since: 01/14/05 | IP: (71.171.20.85) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 877308 posted 02/24/10 11:00 PM     Remind Me!  Send Private Message   Edit Post
Certain cars have the splined ring on the axle itself. This is not the case with our cars. The splined ring is behind the hub where the wheel mounts. You should NOT have done anything to affect the ABS. You did not remove the ABS sensor from the hub during the install by any chance? Other possibilities include bumping during install.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (71.93.13.177) | Report this post to a Moderator
fastasleep
197/2000
Galant VR-4 org Post #: 877346 posted 02/25/10 03:40 AM     Remind Me!  Send Private Message   Edit Post
I may have removed it, and by removed, I mean that I unbolted it from its affixed location to the hub, but reattached it after install. And even then, I replaced it at a later did thinking that I may have damaged it during the axle install, but experienced the same issue.
Ben
197, Evo 3 Powered
Isaiah 43:4
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 877377 posted 02/25/10 09:57 AM     Remind Me!  Send Private Message   Edit Post
That is your problem right there. You need to readjust it so the clearance is correct. When I replaced my front right hub I never rechecked the clearance. The ABS went nuts and would actuate ANY time I hit the brakes. I'm pretty sure what happened is the sensor is too far away from the ring. The sensor doesn't see anything, figures it is between splines, and thinks the wheel is locked up.
I'm not 100% sure if that is how it works, but I would bet money you just need to adjust your sensor.
-Jon Barnes
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.185.58.90) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 877382 posted 02/25/10 10:09 AM     Remind Me!  Send Private Message   Edit Post
In my experience, I had one of the sensors too far out. The ECU knew that the sensor was "bad" in this case and just put the ABS light permanently on. However, it may be possible to have the sensor out of adjustment just enough to just trick the ecu and cause the problems you are having.
I'm not aware of the adjustment procedure, but when mine was giving me problems I just adjusted it to get as close as I could without ever hitting the splines on the ABS ring.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
fastasleep
197/2000
Galant VR-4 org Post #: 877534 posted 02/25/10 06:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting BarnesMobile:
That's exactly what it does.
When it warms up, I suppose I'll jack it up, take the wheel off, and try to position it as close to the splines without touching and see if that fixes it.
Ben
197, Evo 3 Powered
Isaiah 43:4
Galant VR-4 org Post #: 877630 posted 02/26/10 12:11 AM     Remind Me!  Send Private Message   Edit Post
There is a spec, but i don't remember it. Should be in the SM though.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10772 | From: Michigan | Member Since: 03/05/01 | IP: (74.36.84.134) | Report this post to a Moderator
evo8ya
Member +
807/2000
Galant VR-4 org Post #: 877653 posted 02/26/10 06:15 AM     Remind Me!  Send Private Message   Edit Post
As said before, sounds like the sensor is incorrectly spaced causing the ABS to freak out. Loosen it up and move it closer, but be careful not to move it too close as it will contact the ABS ring.
Black Sand Pearl 05 Tacoma TRD Off Road 4X4 - DD
Nile Black 91 807/2000 Sold
Tarmac Black 05 Evo GSR Sold
Apex Silver 03 Evo GSR Sold
Summit White 92 780/1000 Sold
Nile Black 91 259/2000 Sold
Posts: 351 | From: PA/MD | Member Since: 07/07/06 | IP: (174.60.61.111) | Report this post to a Moderator
2 registered and 32 anonymous users are browsing this forum.
Generated in 0.068 seconds in which 0.052 seconds were spent on a total of 14 queries. Turbo powered.
