Galant VR-4 Forums » Galant VR-4 » Technical Discussions » MAP signal as TPS
MAP signal as TPS
blue642
Galant VR-4 org Post #: 852202 posted 11/24/09 11:31 AM     Remind Me!  Send Private Message   Edit Post
So this is more of a discussion thread and I don't really plan on implementing it at this time. It just that I stumbled across it the other day and found it kind of interesting. Figured I'd throw it out there and see where it leads.
I was flipping through an old issue of SCC and was reading an article on turboing KA24DE. I was intrigued by how some of the tricks they used, one of whick was to switch out the TPS and replace its ECU signal with a 2 bar MAP in the manifold. 0-5V signal based on pressure allowed better control, especially when it starting to build boost, as it shows a lot more useful info between the MAF and MAP in regards to how much air is actually going into the engine. Guess I should note that they used rising rate FPR to compensate on the fuel side.
Obviously a trick like this makes sense since the factory ECU for an NA car would more prone to run lean at part throttle. My question is how well would it work compared to our factor MAS and TPS setup, or a standard MAP conversion setup like DSMap or DSMLink w/ MAP which is still used in conjunction with TPS. Since the ECU correlates airflow, throttle, and RPMs to determine which base fuel maps to use, would using a MAP as a replacement for TPS give a more accurate reference by which to pull tables? What kind of effects on low/midrange driveability would it have? Obviously it would take a lot to initially get it up and running, but it seems like it would be more accurate and intuitive to tune.
| | | IP: (147.185.160.242) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 852383 posted 11/24/09 08:10 PM     Remind Me!  Send Private Message   Edit Post
I'm pretty sure people have done this with a VPC set up. I can't remember where but I do remember reading about it and giving it consideration at one point. My car ran very well with the VPC set up the normal way so I decided to leave it alone.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.62.73) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 852403 posted 11/24/09 09:03 PM     Remind Me!  Send Private Message   Edit Post
I believe one of the ways people tune with megasquirt is by setting up the tables to RPM vs. tps, which is kinda doing the opposite.
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (75.87.128.187) | Report this post to a Moderator
Generated in 0.077 seconds in which 0.063 seconds were spent on a total of 14 queries. Turbo powered.
