Galant VR-4 Forums » Galant VR-4 » Technical Discussions » valve question
valve question
Kenny_Kline
belligerent idiot
1370/2000
Galant VR-4 org Post #: 832817 posted 09/23/09 06:41 PM     Remind Me!  Send Private Message   Edit Post
I pulled the head off my car. I am checking valves to see if the seat correctly. I noticed that on cyl 4 & 3 intake valves, they open offset from each other. 1 Opens before the other and closes before the other by a little bit. Cyl 2 & 1 open evenly and close evenly. I spray brake cleaner in ports and let it sit for 10 minutes, no leaks. Is this normal? I am going to test exhaust side next.
Setup: BC 272cams, +1mm OS valves, BC springs/retianers 200 miles since valve job
Kenny @ Dynotech Tuning
[email protected]
Posts: 789 | From: Seekonk, MA | Member Since: 12/27/07 | IP: (72.93.5.15) | Report this post to a Moderator
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 833114 posted 09/24/09 12:27 PM     Remind Me!  Send Private Message   Edit Post
If one lifter is leaking or stuck in a lower position than it's supposed to, would that cause it? Just a thought.
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.20) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 833118 posted 09/24/09 12:41 PM     Remind Me!  Send Private Message   Edit Post
I agree, sounds like one lifter is pumped up more than the other. Have you double checked to make sure the rocker is seated properly on the top of the valve stem?
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.185.58.90) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 833154 posted 09/24/09 02:48 PM     Remind Me!  Send Private Message   Edit Post
You should be able to compare the lifters by looking at the assembled head. Until they are pumped up, though, you can't really use what you are doing to jump to any conclusions. All you can make sure is that when they are closed, the valves seal properly. I disadvantage of hydraulic lifters I guess?
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 833155 posted 09/24/09 02:50 PM     Remind Me!  Send Private Message   Edit Post
Wait a minute, you said one of the valves opens AND closes before the other? I guess that means your cam lobes are offset? Lifters being bled down would make one valve open before, and close AFTER another.
And you're asking if the valve should seal using liquid for 10 minutes? What would you expect to happen; Have it all leak out?
-Jeff
1881/2000
50/1000
Edited by jepherz (09/24/09 02:50 PM)
1 registered and 19 anonymous users are browsing this forum.
Generated in 0.07 seconds in which 0.058 seconds were spent on a total of 14 queries. Turbo powered.
