Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Size Of Oil Cooler
Size Of Oil Cooler
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 680611 posted 08/12/08 09:23 AM     Remind Me!  Send Private Message   Edit Post
I'm going to get a air cooler for my oil setup. I purchased a 90 filter housing.
I'm putting together the other pieces and I'm trying to use stuff that I have laying around my shop.
I have a tranny cooler off of a domestic that's quite large. I plan on using a oil thermostat, like Cy has on his car. That's a really smart idea, due to the climate we live in. I'm just worried that even with the thermostat, the cooler will be too efficient.
Size is 14.5 x 10 inches.
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (68.117.58.112) | Report this post to a Moderator
Flip4G63
Den Mother
1439/2000
Galant VR-4 org Post #: 680618 posted 08/12/08 09:44 AM     Remind Me!  Send Private Message   Edit Post
thats huge man!!
i'm in texas and dont need anything that big. we got 110 weeks here.
91 GVR4 1439/2000 White
Posts: 1154 | From: Abilene Tx | Member Since: 08/28/07 | IP: (66.143.196.74) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 680748 posted 08/12/08 03:42 PM     Remind Me!  Send Private Message   Edit Post
I used a 13-row Mocal unit from Summit or RPW. No gauge to see if it actually helped to lower oil temps or how effective it is/was, but I made it through two seasons of events with no issues. As I understand, the 90 filter housing already has a t-stat inside, so my big one that we installed inline is redundant. You don't need two, but let someone else confirm that the housing has a t-stat inside of it.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.4) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 680762 posted 08/12/08 04:04 PM     Remind Me!  Send Private Message   Edit Post
There is a cooler bypass valve that's temp sensitive IIRC.
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Posts: 3115 | From: Portland, OR | Member Since: 09/10/07 | IP: (76.113.121.3) | Report this post to a Moderator
CarRacer
83/2000
Galant VR-4 org Post #: 680766 posted 08/12/08 04:10 PM     Remind Me!  Send Private Message   Edit Post
Is that the valve we port to lower oil pressure?
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (32.150.6.62) | Report this post to a Moderator
chris
Galant VR-4 org Post #: 680780 posted 08/12/08 04:25 PM     Remind Me!  Send Private Message   Edit Post
i used this ams oil cooler kit. comes with more than enough hose and all the fittings.
Edited by chris (08/12/08 04:26 PM)
| | | IP: (72.200.148.16) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 680782 posted 08/12/08 04:27 PM     Remind Me!  Send Private Message   Edit Post
Definitely not.
The one you want to port is the "relief valve" that dumps back into the pan.
1269/2000 Summit White
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 680794 posted 08/12/08 05:25 PM     Remind Me!  Send Private Message   Edit Post
^^ Correct, here's a picture of the relief valve porting area and location located at the rear ( or closest to the crank pulley ):
The picture from Chris above with the braided line shows the bypass valve directly below the lines ( looks like a big castle nut with plastic cover ).
Mike O.
#464/1000 - Sold
Edited by ktmrider (08/12/08 05:26 PM)
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 680924 posted 08/12/08 11:11 PM     Remind Me!  Send Private Message   Edit Post
Here is a jdm one for reference :
If you want to order these lines & or oil cooler lmk.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (98.144.108.148) | Report this post to a Moderator
CarRacer
83/2000
Galant VR-4 org Post #: 680928 posted 08/12/08 11:19 PM     Remind Me!  Send Private Message   Edit Post
I'll be sourcing all my parts from leftovers in my shop. Thanks for the offer though G.
As for porting and any information related to the 90 OFH, I found this thread to be the best.
If the oil thermostat would be redundant, I could build this one for the price of the adapter fittings to the housing. Pops offered some leftover -10 hose from his Camaro build. I'm not sure if I'll even use that hose though, as the tranny cooler has no provisions for AN fittings. I might get a different cooler though. I'm sure Summit has some for under $50.
James
83/2000
tsiboy
has one ambihelical hexnut
810/1000
Galant VR-4 org Post #: 680934 posted 08/12/08 11:35 PM     Remind Me!  Send Private Message   Edit Post
maybe consider going with a stock rx7 setup. its huge
and mounts an lines look easy
810/1000 Nile black
damn it where did all my 12mm's go
Posts: 1137 | From: Los Angeles, Ca | Member Since: 01/26/05 | IP: (69.230.72.26) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 681797 posted 08/14/08 02:13 PM     Remind Me!  Send Private Message   Edit Post
the 90 housing has a thermostat inside and only puts 10% of the oil through the cooler if it's below 180*
Unless you think you might need a smaller radiator in the winter because your car runs too cold too
Fact is, thermostats are in there to keep fluids at a set temp, not super cool or let them get hot. Pretty nifty.
Are you planning on running a 90 housing, or something else?
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3684 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (67.76.148.180) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 681939 posted 08/14/08 05:41 PM     Remind Me!  Send Private Message   Edit Post
tHERMO killer click I keep forgetting i need to order one of these.
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (66.11.222.178) | Report this post to a Moderator
Generated in 0.087 seconds in which 0.066 seconds were spent on a total of 14 queries. Turbo powered.
