Galant VR-4 Forums » Galant VR-4 » Technical Discussions » EVO springs?
EVO springs?
Kenny_Kline
belligerent idiot
1370/2000
Galant VR-4 org Post #: 636650 posted 04/19/08 08:38 AM     Remind Me!  Send Private Message   Edit Post
Now I know there is a few threads out there of people putting the EVO stock springs in the Galant. I was looking at a set of Eibachs and said to myself, if they EVOVIII stock springs fit in our galant, why not just buy a drop spring made for the EVO.
Eibach Prokit lower the EVO: Front-1.0" Rear-1.0"
Thoughts?
Kenny @ Dynotech Tuning
[email protected]
Edited by krkline2gdsm (04/19/08 08:39 AM)
Posts: 789 | From: Seekonk, MA | Member Since: 12/27/07 | IP: (66.31.109.250) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 637579 posted 04/22/08 10:00 AM     Remind Me!  Send Private Message   Edit Post
go for it. they even probably cost less than gvr4 specific eibachs. almost everything for the vr4 cost MORE except brakes.
| | | IP: (75.37.37.78) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 637581 posted 04/22/08 10:02 AM     Remind Me!  Send Private Message   Edit Post
I'm thinking your rear is going to be dumped and the front will look much higher.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
Armitage
VR4CED
960/1000
Galant VR-4 org Post #: 637681 posted 04/22/08 01:34 PM     Remind Me!  Send Private Message   Edit Post
Note that all the Evo springs out there have stiffer rears than fronts. It's the opposite with our cars - normally the fronts are stiffer.
Here's some info on various Evo springs (scroll halfway down page):
'92 Galant VR-4 #960
'93 RX-7 Twin Turbo
Posts: 715 | From: Herndon, VA | Member Since: 10/16/03 | IP: (64.210.231.126) | Report this post to a Moderator
Myles
Douchebagel with Lox
Galant VR-4 org Post #: 638113 posted 04/23/08 12:24 PM     Remind Me!  Send Private Message   Edit Post
Keep in mind the evo is also lighter then our cars. Also the Rear Springs are much more Narrow and will bow out on the perch. You can correct that by purchasing a spacer from JNZ and Cutting the coil to compensate for the spacer. My old setup was KYB AGX all around with EVO springs in the rear w/ the spacer, and Eibach springs in the front. It had a very aggressive rake to it
1929/2000 *SOLD*
Posts: 5264 | From: Skokie, IL | Member Since: 08/08/06 | IP: (70.91.243.254) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 638192 posted 04/23/08 04:08 PM     Remind Me!  Send Private Message   Edit Post
Actually, the USDM Evo 8 is listed at about the same curb weight as the VR-4.
Evo 9 Curb: 3219-3285 lbs (RS, MR)
Evo 8 Curb: 3269 lbs
Galant VR-4 Curb: 3250 lbs
Both cars are 60/40 weight distribution, hence the reason the Evo suspension works so well when adapted to the VR-4 (not counting the differences in suspension geometry). I'm not sure where the idea came from that the spring rates were reversed, but if the number is fairly small, it's probably being expressed mm/kg instead of kg/mm, N/mm or lbs/in like it usually is. In that case, a lower number means a stiffer spring.
You're thinking of the older Lancer/Mirage chassis Evos, which are much smaller and lighter from the Evo I at 2579-2734 lbs to the Evo 6 at 2756-2996 lbs. The Evo has steadily increased its waistline over the years, and the added technology systems, the jump to the Cedia platform and the USDM safety and emission package didn't help. This is why the Evo 1-6 are generally regarded as better performing cars (That and the fact that they were homologated Group A rally cars as opposed to just high performance street cars like the VII onward). The Evo WRC shares very little besides the engine and general appearance with the newer generation roadgoing versions.
So the saying goes for engines you can make a lot of tweaks, but ultimately there's no replacement for displacement, for improved handling, there are tweaks, but no substitute for several hundred pounds of weight loss.
1269/2000 Summit White
Edited by Dialcaliper (04/23/08 04:17 PM)
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
2 registered and 9 anonymous users are browsing this forum.
Generated in 0.071 seconds in which 0.057 seconds were spent on a total of 14 queries. Turbo powered.
