Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 1990 vs. 1991 O2 Sensor (DSM)
Senior Ricer
1552/2000
Galant VR-4 org Post #: 554668 posted 10/27/07 09:44 PM     Remind Me!  Send Private Message   Edit Post
I know there is a difference in the two of them but can someone either explain the difference or post a link that does? I've got a nice, fairly new Bosch unit that was in my GVR4 for a little while. I'm planning on putting it in the 1990 1G that I have apart ( THREAD ) but I'm getting conflicting info based on part numbers.
Bosch lists part number 13598 for both 1990 and 1991.
Denso lists part number 234-4643 for 1990 DSMs and 234-4007 for 1991's.
I'm guessing that the voltage output is slightly different for the two different model years but I'm concerned that the wrong sensor would skew the fuel trims' accuracy.
Thoughts?
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.59.65) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 554676 posted 10/27/07 10:21 PM     Remind Me!  Send Private Message   Edit Post
Looks like the plugs are different.
1990 = # 24533
1991 = #24225
I can check my ntk book on monday to see if the universal type is the same for both.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (69.81.202.212) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 554720 posted 10/28/07 06:12 AM     Remind Me!  Send Private Message   Edit Post
Weird. Maybe the Bosch one has the pins located so that they could reach either 1990 or 1991 and up.
Thanks G.
John
crankwalk
Galant VR-4 org Post #: 554807 posted 10/28/07 03:40 PM     Remind Me!  Send Private Message   Edit Post
I have always used the 90 style ever since I found out they have more holes and tend to read more accurately and be more responsive. I guess Mitsu started cheaping out in 91.
| | | IP: (24.99.218.210) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 554808 posted 10/28/07 03:49 PM     Remind Me!  Send Private Message   Edit Post
Interesting. I grabbed the 1991 O2 sensor that I'm planning to use and tried it on the 1990 Talon harness. It fits perfectly on the 1990 connector so that connector won't be an issue.
John
JDM Unit
486/1000
Galant VR-4 org Post #: 555087 posted 10/29/07 10:33 AM     Remind Me!  Send Private Message   Edit Post
The only difference i am seeing is the 1990 has more holes & has a 755mm wire length & the 1991 has a 730mm wire & fewer holes.
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (74.9.164.34) | Report this post to a Moderator
324vr4
manly-loud yet refined
324/1000
Galant VR-4 org Post #: 555100 posted 10/29/07 11:24 AM     Remind Me!  Send Private Message   Edit Post
So it is recommended to use the '90 than, correct?! With more holes and longer harness wire I don't see another route...
Posts: 1240 | From: Bozeman, Montana | Member Since: 04/28/06 | IP: (69.51.103.82) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 555102 posted 10/29/07 11:25 AM     Remind Me!  Send Private Message   Edit Post
Alright. I'll try the 1991 sensor since I have a nearly new one in the 2G O2 housing that I want to use on the Talon.
Thanks!
John
Generated in 0.15 seconds in which 0.108 seconds were spent on a total of 14 queries. Turbo powered.
